What kind of amp should i get for 2 12'' Solobarics
BigHairyMonkey
411
Houston (Bellaire) TX
im getting 2 L5 solobarics and i was wondering should i get them in dual 4 ohm or 2ohm and whats the diff. I possess basic knowledge in amps/subs/etc and was gonna power this stuff with a hifonics brutus bx1605d mono 1600rms@1ohm and 1100rms@2ohm. How do i wire up the voice coils to run in 1ohm or 2ohm...? and another stupid question is how can a mono amp run 2 subs... or do i have the wrong idea of what mono stands for. sorry for the dumb questions:D
The total rms wattage for the L5's is 1200 watts, and the hifonics is putting out 1100 at 2ohms. So you will need to get the dual 2 ohm voice coil L5's. You will wire them in series at the subs and then wire them parrallel at the amp netting you 2ohms of resistance and 1100 watts of power.
2ohm-series-2ohm-----2ohm-series-2ohm
------(X2)-------------------(X2)-------
-----4ohm----parallel------4ohm-------
----------------(1/2)-------------------
------------2ohm resistance-------------
When the time comes to wire the subs up and you're lost, just give me a PM or a post on here and i'll walk you through it.
