  • SN95 4.6L Mustang Tech
what mod would u do next???
  • Thread starter Thread starter sliver02GT
  • Start date Start date Mar 7, 2004
sliver02GT
84
  • Mar 7, 2004
ok i got 400 or so, what should i get next
3:73 gears
New Nittos for the rear
New 70mm TB and Intake
daver01
396
Lexington, Ky
Mar 7, 2004
  • Mar 7, 2004
gears, without a doubt, best thing i've done to my car. but get 4.10s. just kiddin. sorta.
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 7, 2004
  • Mar 7, 2004
4.10 man.. it should run you around $400 for both gear and installation
W
wickedgt70
178
San Jose, CA
Mar 7, 2004
  • Mar 7, 2004
Gears. 4.10 minimum. The RPM difference between the 3.73 and the 4.10's is minimal but the acceleration difference (SOTP) is much better with 4.10's in my opinion.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Mar 7, 2004
  • Mar 7, 2004
Mind if I ask, do you have a stick or automatic ? I only ask because its going to affect the decision of what we tell you.
If youre planning on staying n/a, I would go with 4.10s or 4.30's instead of 3.73's. Like Wickedgt70 above said, the rpm difference between the two ratios is minimal but 4.10s give better performance. If youre supercharging, Ide stick with 3.73's. Should you decide to get the gears, I recommend www.stangstore.com as the place to buy them from as they will be cheaper than most other places.
Sticky tires are a good idea and you will need them once you switch gears. That much I can assure you. I personally dislike the idea of the throttle body. Its been shown MANY times that no real power gains are offered with a larger throttle body vs. the stock one.
JonJon
4,801
back in Marylands
Mar 7, 2004
  • Mar 7, 2004
Nitto's on back.
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
