  • SN95 4.6L Mustang Tech
What now?
  • Thread starter Thread starter OC Stang
  • Start date Start date Oct 17, 2008
O
OC Stang
83
Orange County, CA
Oct 17, 2008
  • Oct 17, 2008
I just got my car dyno tuned today and I was running super lean. Car runs much smoother now. I put down 251/285.
So basically I believe I am maxed on on power without getting into the engine or adding a power adder of some sort. Only thing I have not done is touch the headers, but those seem like such a pain to do if I stop there. You should be able to see what I have in my signature. Any thoughts on something else I can do to my car power wise? Where do I go from here? Also I have 98k miles on the car now.
evil281
276
Arizona
Oct 18, 2008
  • Oct 18, 2008
100 shot, done!
O
OC Stang
83
Orange County, CA
Oct 18, 2008
  • Oct 18, 2008
evil281 said:
100 shot, done!
Not interested in running NOS...thanks though.
Crzyhrse
Seattle, WA
Oct 18, 2008
  • Oct 18, 2008
3.73's or 4.10's.
mransr
1,188
36
98
Riverside, SoCal
Oct 18, 2008
  • Oct 18, 2008
not to hijack (too much...)
where'd you get it tuned?...I'm looking for somebody in the soCal for a dyno tune
and I don't see cams in your sig...that might be a good 'next step'
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 18, 2008
  • Oct 18, 2008
cams and lt's.........
blubullett
535
Modesto, CA
Oct 18, 2008
  • Oct 18, 2008
Ported heads, stage one cams, and some jba shortubes. Long tubes are better but you would have so swap them to smog.
O
OC Stang
83
Orange County, CA
Oct 19, 2008
  • Oct 19, 2008
I thought about cams and LTs as others mentioned, but I don't really want to bother with the LTs unless I can pass smog with them. I don't want to switch those out every time I have to smog. Too much of a pain. Maybe cams, but I have heard they won't add too much power for the money.
As for the tune, I got it from SoCalTuning.com. They are located in Anaheim. They are also known as Superior Automotive. Socaltuning.com will put you in touch with the appropriate person. Owners name is Shawn.
nyuk98gt
1,427
Chesterfield, MO
Oct 19, 2008
  • Oct 19, 2008
OC Stang:
After you get gears, cams WILL produce a good increase in power. Some cams will produce up to 40 RWHP at peak and 15 to 25 RWHP 'on average'. Choose wisely because an aggressive cam will (a) give you smog problems and (b) produce power at high RPM and (c) generally reduce hp/torque at low RPM. If this is your daily driver and not a frequent dragstrip car, then you ought to consider 'stage 1' cams: good gains without bad side effects.
HTH,
Chris
G
GettinThere
553
Central Texas
Oct 20, 2008
#10
  • Oct 20, 2008
  • #10
Crzyhrse said:
3.73's or 4.10's.
+1 on the 4.10s
O
OC Stang
83
Orange County, CA
Oct 21, 2008
#11
  • Oct 21, 2008
  • #11
nyuk98gt said:
OC Stang:
HTH,
Chris
Yeah, I would consider stage one cams, but definitely don't want smog problems or lose any low rpm power. That is what i like the most. I don't rev her out too much. Definitely not dragstrip car. I just like punching it on streets and freeways. Or just plain showing off.
R.J.
813
Warwick, Rhode Island
Oct 21, 2008
#12
  • Oct 21, 2008
  • #12
+2 4:10 gears
Mattstang04
1,152
144
104
St. Louis, MO
Oct 21, 2008
#13
  • Oct 21, 2008
  • #13
You can really show off with a supercharger. Not to hijack but what was your hp and tq before the tune or did you not get a baseline?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 21, 2008
#14
  • Oct 21, 2008
  • #14
That is pretty good numbers for a light bolt on Stang. Cams are worth it if you do it yourself or if you can find a lightly used set cheap. I picked up mine with about 6000 miles on them for 350. Nearly 75K miles later and still going strong.
O
OC Stang
83
Orange County, CA
Oct 22, 2008
#15
  • Oct 22, 2008
  • #15
I did not get a full baseline. They tried to do one but cut it off before winding it out.
My car was detonating big time. It was running very very lean. Was like above 14 or 15 in A/F Ratio. Measurement was 219hp at first, but like I said did not wind it all the way up. Made some adjustments on second run got 239hp. Then adjusted again and got the 251. The guys said he was gonna try and get 260, but forgot that mustangs he tuned that got that high had long tubes.
Mattstang04
1,152
144
104
St. Louis, MO
Oct 22, 2008
#16
  • Oct 22, 2008
  • #16
Im currently considering cams. Seems like the next step to more horsepower without getting a supercharger. If you havent got gears yet, you will not be let down. I have a long commute so I got 3.73s. If I didnt want a supercharger in the future and worked closer to home I would have gotten 4.10s. Seems like everyone I see with 4.10s has broke into the 13s in the quarter mile.
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
