  • SN95 4.6L Mustang Tech
What Numbers With KB Kit?
  • Thread starter Thread starter GH1086
  • Start date Start date May 26, 2005
G
GH1086
  • May 26, 2005
I will be running a KB 1.7L intercooled kit, only other mods would be gears, torque converter, full exhaust (long tubes, x-pipe, cat-back), and suspension mods, I will only run the kit with around 7-9 PSI. I want it to be very safe to run, at not blow the motor. What kind of HP numbers would I be putting down with this combo, I'm saying somewhere around 360WHP, but I am not sure, so if anybody can chime in, that would be great.
02LaserRed2V
379
Augusta, GA
May 26, 2005
  • May 26, 2005
The #s I've seen vary greatly. I've seen 5-speeds with no additional mods dyno as high as 400 and as low as 340. That's with the 9 PSI intercooled kit. With an auto, I'd expect 360-380 with your mods. I only have 4.10 gears, magnaflow CB and is expecting "only" 350-ish.
Really, I don't know. Someone who already has one could answer this better...
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 26, 2005
  • May 26, 2005
No, you're about right.
tl75keith
69
Owings Mills, MD
May 27, 2005
  • May 27, 2005
90% of what you'll make depends on the tune. Some guys have great luck with KBs supplied tune, some don't. Engine longevity and maximum power are inversely related here.
I'm running 7# non-intercooled and making around 330-335rwhp. With your intercooler you can run more timing to bump that number up. Just be sure to dyno it before and after your install.
2000BLKGT
361
Toronto
May 27, 2005
  • May 27, 2005
We're getting 340 with my 6# kit.
I've seen 350 with a 9# IC kit. (stock exhaust)
I've seen 400 with a 9# IC kit
A buddy just went forged and will go 14# after the break in period...he's looking for 500
MT1083
1,033
Charlotte, NC
May 27, 2005
  • May 27, 2005
I've got 410 hp and 420tq SAE on mine with exhaust and intake mods.
2000 4.6
927
Northern VA
May 27, 2005
  • May 27, 2005
I made 411rwhp and 426rwtq on mine. This is with the chip KB supplies. Mods in sig.
back_in_black
460
frederick, MD
May 27, 2005
  • May 27, 2005
with the 9 lb intercooled and big tube option, stock throttle body in my auto I was 365 rwhp and 384 rwtq, put on throttle body to go with big tube and 10 lb pulley, was at 395 rwhp
02mingreyconv
127
Bartlett, IL
May 27, 2005
  • May 27, 2005
I made about 400/400 with the KB supplied chip. This was running dangerously lean. I had it retuned by an experienced SCT tuner and my current SAE numbers are in sig. My mods are in sig as well.
back_in_black
460
frederick, MD
May 27, 2005
#10
  • May 27, 2005
  • #10
02mingreyconv, I have the same guage setup and love it !!!!!!!
02mingreyconv
127
Bartlett, IL
May 27, 2005
#11
  • May 27, 2005
  • #11
Yeah, I dig mine too. I had the KB supplied gauges on there for a while but they look cheap. So I decided to go with the full setup.
Simco (SP?) makes a similar one without the broncos horsie on it now that is looking good aswell for about $250. I got mine slightly used (mint condition) for $300 shipped... I could not pass it up
03trubluGT
1,067
Mansfield, TX
May 27, 2005
#12
  • May 27, 2005
  • #12
See sig.
2001sleeper
136
#13
  • May 27, 2005
  • #13
how big is the stall and is it a locked or unlocked TC? This will play a large factor in your dyno numbers.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • dan50
  • Jul 18, 2026
dan50
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
