What oil ?
For storeage purposes you should use a thinner oil. I personally step all the way down to 5w-30 since I don't drive the car in the winter. The thiner oil has an easier time re-circulating in the engine after it's been sitting for long periods of time.
Run your favorite brand of oil (shouldn't really matter) and then any oil filter other than Fram
For me it was Valvoline oil and Motorcraft Filters.
Georgie said:
is it ok to use 5w-30 during the summer too??
It would probably be fine, especially being in the north. I live in Michigan and run 5w-30 in all my cars. The lighter weight oils lube a cold engine at startup best. If you lived in a real warm climate you might want to step up to a thicker oil but for us in the north, 5w-30 will do.
Use the best oil that you can afford to change every 3000 miles.
Synthetic oils are really good in engines that have low miles since new or rebuild. If your engine is over 100,000 miles, and you live in a cold area, it gets a little harder to choose. Thin oils may burn off too quick, but thick oils make the car hard to crank.
5w-30 - Thinnest
10w-30
10w-40
20w-50 - Thickest
These are all the common weights of motor oil used in motors like ours. There are other blends, but these are the most common.
Do you start the car up during the winter?
I'd note that 5W-20 works and is a blend. Synthetics have zero weights as well.
Good luck.
I'd let it run to full operating temps - this will allow flashing of inpurities in the oil.
If it's real cold in your parts (I grew up in Alaska; that's my point of reference), using a PAO synthetic might not be a bad idea (PAE clings to metal better but also has an affinity for water). This will help out during the infrequent start-ups. I'd use something like 0W M1, but that's just me.
Good luck.
