  • 2005 - 2014 Specific V6 Tech
What Problems Will A 2008 V-6 Have
  • Thread starter Thread starter 89llx
  • Start date Start date Dec 2, 2016
1 of 2 Next Last
89llx
5 Year Member
Aug 31, 2009
302
Dec 2, 2016
  • Dec 2, 2016
looking at a stang [2008] with a v-6, is their any known problems with that motor and auto trani?
thanks
Adieu
Easy there, this ain't a dating site.
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Dec 3, 2016
  • Dec 3, 2016
Listen VERY closely to that 4.0 for rattling noises at the back of the engine and check the engine for sludge. The 4.0s are pretty great if they're maintained, but if the oil isn't changed often enough it WILL sludge. If it even starts to sludge a tiny bit, it will lead to timing chain issues, and it will usually be the rear chain, which requires removing the engine for replacement.
89llx
5 Year Member
Aug 31, 2009
302
Dec 3, 2016
  • Dec 3, 2016
thank you soooooooo much
I was thinking only the older ones still had that rear timing chain going bad
Adieu
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Dec 3, 2016
  • Dec 3, 2016
All 4.0s are prone to that problem if not properly maintained. When they are properly maintained they'll go 150,000+ miles before any hint of chain noise and another 20k or so before it's critical in most cases.
89llx
5 Year Member
Aug 31, 2009
302
Dec 3, 2016
  • Dec 3, 2016
cant you just pull the trani and get to the rear chain?
Adieu
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Dec 3, 2016
  • Dec 3, 2016
Nope. No room between the back of the engine and the firewall to get to the plugs you need to remove to get to everything. I've done the rear chains in an Explorer and a Mustang, both times the engine had to come out.
Mirage
Dec 3, 2016
  • Dec 3, 2016
Also, check the thermostat housing. If it is a platic unit, you may want to replace it. Yes the plastice unit can be had for as little as $45 if you look around, but you may want to look into getting an all aluminum housing. It's pretty pricey, and can be found on ebay and amazon, but I've had mine for about 3 years and never had an issue. The plastic housing failing was the very first issue I had with the car and it started right after I bought it. I couldn't find the leak, but lost coolant daily, and could always smell it. Finally found the split seam, and replaced it. End of story. No problems since. The original is prone to failure.
Reactions: Noobz347
89llx
5 Year Member
Aug 31, 2009
302
Dec 4, 2016
  • Dec 4, 2016
Thanks guys, Mirage ,what year was your car with the thermostate housing problem?
Adieu
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Dec 4, 2016
  • Dec 4, 2016
All years of the 4.0 sohc are prone to thermostat housing failure. It's more common in the truck and SUV applications because they run hotter, but they show up in Mustangs from time-to-time as well.
89llx
5 Year Member
Aug 31, 2009
302
Dec 4, 2016
#10
  • Dec 4, 2016
  • #10
anything else? like water leaking into the cabin?
thanks
Mirage
Dec 4, 2016
#11
  • Dec 4, 2016
  • #11
Mine is a 2005 Convertible bought it used, 56k miles on it.
This is a very common problem on the S197 models, but easily prevented. Clean the cowl drains regularly. This is probably the #1 cause of water entering the cabin. And it can be an expensive one.
Also, (I think it was the very first reply), someone mentioned the rear timing chain, or timing chain noise in general. Although I have not personally experienced this in person, One thing that would probably be a good idea would be to replace the 2 timing chain tensioners. They are basically little spring loaded pistons that press against the timing chains (front and rear), and keep the chains from slaping and destroying the plastic chain guides. They are easily accessable without opening the engine, takes about 10 minutes to do the job. Of course this depends on milage on the engine, but I think Ford recommends replacing them every 75k miles. I replaced mine (because I thought they were failing but they weren't) at 105k. The pair cost about $150 bucks, but give me piece of mine when I pulled the old ones out and felt the difference in spring tension.
There are all kinds of theads on this, cowl leaks, and the thermostat housing failure if you need more confirmation. Hope this helps.
89llx
5 Year Member
Aug 31, 2009
302
Dec 4, 2016
#12
  • Dec 4, 2016
  • #12
anyone have a pic of the cowl drain?
thanks
Mirage
Dec 4, 2016
#13
  • Dec 4, 2016
  • #13
Check out this video, it explains it all. There is also a drain on the drivers side you need to check.
Also notice the gromets where the cowl vent (covers) mount, they too deteriorate with wear and time. They too will cause leaks if not addressed.
View: https://www.youtube.com/watch?v=6PuSsGm5OYA
89llx
5 Year Member
Aug 31, 2009
302
Dec 4, 2016
#14
  • Dec 4, 2016
  • #14
man thanks, ,that was real good!!!
how durable are the automatic trani,s on the v-6,s ?
Adieu
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Dec 4, 2016
#15
  • Dec 4, 2016
  • #15
Really durable. I've never personally seen a failure on them in a Mustang, even on beat-to-hell trade-ins. I have heard of them failing on modded cars though.
Mirage
Dec 4, 2016
#16
  • Dec 4, 2016
  • #16
I agree. At stock power levels they seem to hold up well. I have heard they do have their weak points, but so far I have no experience with them. If you go the turbo or super-charger route, you will definately be looking at improving the transmission and rear end. One of the most common mods is to swap out the stock 7.5" rear for the 8", positraction, model off of the GT's.
89llx
5 Year Member
Aug 31, 2009
302
Dec 5, 2016
#17
  • Dec 5, 2016
  • #17
thanks guys !!!!!!
Mirage
Dec 5, 2016
#18
  • Dec 5, 2016
  • #18
Any time. So are you going to buy the '08?
89llx
5 Year Member
Aug 31, 2009
302
Dec 5, 2016
#19
  • Dec 5, 2016
  • #19
Im looking at an 08 automatic , 4.0
I have a 95gt with a 5.0, that has been buillt proff, almost 400,000 mile [no kidding]
just have not pulled the triger yet
89llx
5 Year Member
Aug 31, 2009
302
Dec 9, 2016
#20
  • Dec 9, 2016
  • #20
How do i tell if a mustang is a premium model
the one im looking does not say, but it looks like it has a shaker sound system
thanks
1 of 2 Next Last
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
C
Inline 6 wanted 200 ci
  • Capnkev
  • Mar 2, 2026
  • Want to Buy
Want to Buy Jul 16, 2026
Capnkev
C
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
L
Progress Thread 1977.5 Mustang 2 advice.
  • LittleBlueM2
  • Mar 20, 2025
1974 - 1978 Mustang II Talk & Tech Mar 22, 2025
extra_stout
