What shifter linkage?
What shifter linkage? I just installed a 1978 C-4 in my 66 and the old linkage wont work. On the old C-4 the lever on the tranny was pointing up and on my 78 tranny the lever is on the bottom. Would I go to the bone yard and get the linkage off a car that the tranny is in the down position? Thanks
Only way to fix that is to use an aftermarket shifter with a cable. Or put the old C-4 linkage on the newer transmission. You've in effect, reversed the sifter pattern. If you could ge the linkage rod on, the pattern would be reversed.
