What size gears should i use?
GTIF
25
I thinking about changing my stock gears in my 02 AOD GT, But I'm not certain on what size. I cruise at 2200rpm in overdrive @60mph and 2800 with the overdrive off. A friend of mine said 3.73 will raise the r's in o/d to about2800 and gain ample amount of power and drop considerable time in the ET aswell as gas mileage.(.40/h/w9gal. less)
This is my daily driver and weekend burner.
What do you guys think about this gear? I looked around on some of the other forums, But they were all about 5-speeds:(
4.10s are a perfect gear for the 4.6, especially autos. i see you're pretty new to the boards. just warning you, expect a few smart ass replies about using the search option.
but 4.10s all the way. if you cant convince yourself to get them, then 3.90s at the highest. motive makes the 3.90s btw.
I got 4.10s in my 04 GT/auto. With firmed up shifting from a handheld tuner, I get 2nd and 3rd gear scratches. You put less strain on the transmission and you spend more time in the converter lock up gears (3rd and 4th). Driving in every gear is more fun. The only downside is my highway cruising. I used to cruise comfortable at 70-75 mph at 2100-2200 rpm. Now, I find myself cruising in the right lane, doing 55-60 in the same rpm range. I can go 75-80 and it feels great but my rpms are at 2800-3000. It feels like roadracing. It's all about smiles per mile anyway.
I have 4.10's
for a auto id recommend 4.10's
and for a 5 speed id go with 3.73's
Them there gears sounds prety good.:nice: do any of ya all do a before and after install run at your local dragway?
You guys are convincing me much more than i thought.So, all i need to know is how are they at the track.
Are you sure you've got stock gears GTIF? The math isn't working out with the RPMs and speed your showing above. What size tire are you running?
With stock gears and tire size at 60mph in OD you should be about 1800 rpm and 2550 rpm with OD off. The attached calculator will help you figure out what rpms you'll be running at different speeds with different size tires.
http://www.wcfords.com/stuff/calcs/EGTcalc/egtcalc.php
