What size wire gauge??
  • Thread starter Thread starter Gixxer750
  • Start date Start date Jun 20, 2004
Gixxer750
789
Saint John NB, Canada
Jun 20, 2004
  • Jun 20, 2004
I am wiring my driving lights up to one of my switches on my UPR Ash tray switch panel in my 87 GT. What size wire gauge should I use and what size fuse??
Right now I keep blowing 30amp fuses but I think the 14 gaguge wire is too small.
Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Jun 20, 2004
  • Jun 20, 2004
I'd run 10 gauge
Gixxer750
789
Jun 20, 2004
  • Jun 20, 2004
Mustang5L5 said:
I'd run 10 gauge
How bout fuse size??
conartist
77
Windsor, Ontario, Canada
Jun 20, 2004
  • Jun 20, 2004
Remember your electrical equations now,
Watts = Volts X Amps
For example, if you are running two H3 bulbs rated at 55 watts a piece,
110 w/ 12 v = 9.167 a
Therefore, you should run a 10A fuse....
As for the wire size,
0-10A
Up to 4'(16 Gauge)
4' to 7'(14 Gauge)
7' to 10'(14 Gauge )
10' to 13'(12 Gauge )
10 - 20A
Up to 4'(14 Gauge)
4' to 7'(12 Gauge)
7' to 10'(12 Gauge)
10' to 13'(10 Gauge)
20 - 35
Up to 4'(12 Gauge)
4' to 7'(10 Gauge)
7' to 10'(8 Gauge)
10' to 13'(8 Gauge)
hllon4whls
BANNED
2,567
Covington
Jun 20, 2004
  • Jun 20, 2004
You should run those lights off of a relay. You size your fuse slightly higher than the current draw of the device. If the lights draw 9 amps, I would run no larger than a 15 amp fuse. For a motor, it is a little different. For a 9 amp draw motor I would run a slightly larger fuse for startup current. Wire gauge is dependent on the distance. A 10 gauge wire would work from a relay to the battery and to the lights. Might be too small if the bat is in the trunk!
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
