What the hell gives?!?!?
  • Thread starter Thread starter 02GTRX
  • Start date Start date Jan 4, 2008
02GTRX
I told an admin to shut up...now I live with the S
20+ Year Stangneter
Sep 27, 2004
213
  • Jan 4, 2008
Why does my stupid car cut out at 140 when my stock 02 gt would do a tad over 145 at the test your top speed track here in NM?! Not only that but it felt like a boat! My 02 felt grounded and solid at that speed, does a 2inch drop really make that big of a difference at that speed???
Humboldt Stang
64
  • Jan 4, 2008
Get a tuner and turn off your speed limiter
Emay
228
South Elgin, IL
Jan 4, 2008
  • Jan 4, 2008
+1 on the tuner and elmination of limiter, and yes lowering the car makes a huge difference as does the other supporting suspension mods. Not only does the car handle tighter and a bit more nimble, but you cut the wind from beneath the car which makes for a significant stability increase as opposed to the 4x4 height. When travelling at these type of speeds for long durations of time, in these s197 platforms it's a host of things that really are making you get the sensation your feeling.
F
FFR snakeman
70
virginia
Jan 4, 2008
  • Jan 4, 2008
hope you were on a track at that speed
05xgt
78
spring tx
Jan 4, 2008
  • Jan 4, 2008
You need to kill your speed limiter. OOOps that was mentioned, my bad. Sorry.
Troy-Stangsaver
  • Jan 4, 2008
did some one mention to turn off the limiter?
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Jan 4, 2008
  • Jan 4, 2008
I think you need to turn off your speed limiter.
Where's Big cat? He'll know.
Khyron
68
Lincoln, NE
Jan 4, 2008
  • Jan 4, 2008
Just like everyone else said, get a tuner and turn off the speed limiter. I compete in open road racing, and I can vouch that these cars will do 160.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jan 4, 2008
  • Jan 4, 2008
i didnt want to postwhore. but, since i was requested, here is my reply.
get a tuner and turn off the limiter. they are set to limit at 143, IIRC. speedo error, tire wear, viewing angle of the gauges, etc. could have caused the slight difference between what you saw on the speedo and where the ECU limited speed.
also, as mentioned already aerodynamics play a huge part in handling at those speeds. in case you have not heard, the S197 is not as aerodynamic as the new edge stangs.
DarkFireGT
692
10
89
East Moline, IL
Jan 4, 2008
#10
  • Jan 4, 2008
  • #10
Dangit.. You weren't supposed to get all techinical. You were supposed to just say turn off the speed limiter.
T
The Fang
602
Tallahassee Fl
Jan 4, 2008
#11
  • Jan 4, 2008
  • #11
My gosh, why would you want to go that fast anyway? I've had mine over two years and it has never been over 80.
Marine One
276
North Topsail Beach, NC
Jan 4, 2008
#12
  • Jan 4, 2008
  • #12
Mine's never been over 80 either... in second gear that is...
06 roush
44
#13
  • Jan 4, 2008
  • #13
hey why dont you turn off the speed limiter .not sure if anyone above me mentioned that
SpartaPerformance
2,517
61
89
Long Island NY
Jan 4, 2008
#14
  • Jan 4, 2008
  • #14
I didn't bother to read most of the posts however I understand that you have factory ride height. Lower it and it will feel more stable, Ford cool their radiators from air coming underneath the bumper by the front valance (thats why so few holes in your grill) that causes the nose to lift. I had mine to 120mph at factory ride and scared the balls off me, after lowering I got to 130 and she was stable!!
bigcat
May 1, 2005
3,015
7200 feet
Jan 4, 2008
#15
  • Jan 4, 2008
  • #15
:SNSign:
02GTRX
20+ Year Stangneter
Sep 27, 2004
213
#16
  • Jan 5, 2008
  • #16
How low can I go before i start running into alignment problems? on my 02 i had the sportlines with caster camber plates and had would be lucky if my front tires lasted a year. thats a problem i dont want to have on my new car. would a 1.5in drop be enough to eliminate that boat feeling yet not give suspension issues?
SpartaPerformance
2,517
61
89
Long Island NY
Jan 5, 2008
#17
  • Jan 5, 2008
  • #17
The FRPP handling package comes with camber eccentric adjustment bolts so you can set the camber to proper specs...It doesn't specify in instructions but they have to be installed on the strut the opposite way the factory bolt came off (easier to adjust) which requires removal of the brake caliper off the rotor. It took me 3hrs and I'm a spaz with 10 thumbs....my employees were keeping a close eye on me with wrenches ready to jump in. Hardest part was putting together the rear billet sway bar links...I hope you're strong.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
