What wrong with this.. (pics)mustang
  • Thread starter Thread starter mustangsally93
  • Start date Start date Apr 8, 2006
  • 3
  • 4
First Prev 2 of 4 Next Last
94GT347
29
Houston
Apr 8, 2006
#21
  • Apr 8, 2006
  • #21
Just curious, did you pull any of the valves out of the heads at any point?
Even though you torque the rocker nut to a certain value, you still have to shim under the pedestal to get the correct valve lash. I'm sure someone has already taken the time to detail the procedure on here. I'd try a search.
I agree with the other poster.....if nothing obvious, go back together with it. Very doubtful you have a ring issue on 3 cylinders.
If it was a cheby, you could just swap sides on the heads. Then you could verify if it is a vlave or short block issue by comparing new compression readings to the old ones.
Ford has a "special" insert in a bolt hole in one end of the head that makes it side specific. You may be able to back it out and put it in the other end?
Fox_84
143
#22
  • Apr 8, 2006
  • #22
Just a suggestion but when you torque the head bolts down, are you going in a circle or are you starting in the center and working your way outwards? If you have a haynes or chilton manual it will show you the order to start in the center and work your way outwards and do so correctly. I really dont feel this is it though.
I dont have a lot of experience with the 302, on my second one, but I do have much experience with engine work.
There is most likely 2 things it could be.
1st you may have rings that are sticking or the gaps are in align with each other and they shouldnt be.
2nd you may have a couple of burnt valves or valves that are adjusted tighter than they should to be.
Rings Sticking. You can put a teaspoon of Marvel Mystery Oil in each spark plug hole and circulate that and usually rings will free up. But since you had pistons out, I doubt it is that.
If you have the gaps on the rings on a single piston in align, you can loose compression here. The gaps on each ring should not be in align with each other.
As far as valves, it is hard to explain to you how to adjust them, but this is what I fee it is. I figure the valves have been tightened too far.
Your primary problem, I will have to agree with others, it was probably not internal, but you will just have to go from there once you figure out your comperssion problem, because that is definitely not right.
mustangsally93
281
Omaha,NE
Apr 9, 2006
#23
  • Apr 9, 2006
  • #23
Well the pistions were never out. Also I did a gap feeler and all the ring were fine. Also no marks on the pistions walls. We also put a but load of oil on the wall and worked it in. the heads were never missed with other then them being off. So in the morning I well redo the rockers and tighten them down less. The heads bolts are done right in the order they should have been done.
C
custom89stang
705
Seattle, WA
Apr 9, 2006
#24
  • Apr 9, 2006
  • #24
i know its been a while, BUT do i dare say go back to square one? and every step of the way, make sure you get consensus on everything you do (torque specs,etc)?
74courier
158
vancouver wa
Apr 9, 2006
#25
  • Apr 9, 2006
  • #25
if it was like my car when i got it the heads wernt tourqed right and the pushrods where a lil to short with about 30mins of work i had a good running motor again and close comp ratios between 125-137[most read at 125-129]. id get a pushrod length checker from summit or a local parts store.
mustangsally93
281
Omaha,NE
Apr 9, 2006
#26
  • Apr 9, 2006
  • #26
ok ok Well in about 4 hours Im going back to work on it. I really don't know why the size of the push rod matter but ok I well check. And I well tighten the rockers to 15-20 and not 25-30. Also could it be the head gaskets Im using. I'm using trick flow head gaskets and not oem. Could this do anything????
mustangsally93
281
Omaha,NE
Apr 9, 2006
#27
  • Apr 9, 2006
  • #27
I dont know why it posted three times
mustangsally93
281
Omaha,NE
Apr 9, 2006
#28
  • Apr 9, 2006
  • #28
ok
G
getusummm
156
#29
  • Apr 9, 2006
  • #29
I was under the impression that the 91 or 92 and later head bolts were of the torque to yield variety and should not be reused. The cam is very easy to time, just line up the marks on the sprockets.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Apr 9, 2006
#30
  • Apr 9, 2006
  • #30
Yes you cant reuse torque to yield bolts.
Sould get a set of ARP bolts,even used they are far better than a factory bolt.
Mustang5L5
Mod Dude
Feb 18, 2001
43,336
18,062
224
Massachusetts
Apr 9, 2006
#31
  • Apr 9, 2006
  • #31
That's right, you can't reuse the '93's head bolts. Once they are off they are done.
Maybe that's why the compression was down on the end cylinders? Possible the head was slightly lifting there???
Black1987Stang
1,422
Jersey Shore
Apr 9, 2006
#32
  • Apr 9, 2006
  • #32
Im also thinking its a rocker problem, i had redone my stock heads, cut the valves and seats and never then never shimmed the rockers so in one cylinder i had like 9psi of compression hah, i put in one shim and went back up to 150. i no u didnt get ur heads worked on just saying though. U said u had the cam out, are the dots ligned up? once u get the heads on, turn each cylinder to top dead center and hook up compressed air and see where air comes out, if its the intake or exhaust pipe then u no its the valves, if its the breather or oil dipstick its the rings...btw did u try a wet compression test too
J
JRPony
83
Las Vegas, NV
Apr 9, 2006
#33
  • Apr 9, 2006
  • #33
Technically, TTY bolts are one time use only, but they will still provide equal clamping force the second or third time that their used. Its the shear /tensile stength that is reduced. What I'm saying is, reusing TTY bolts will not reduce compression #'s.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Apr 9, 2006
#34
  • Apr 9, 2006
  • #34
They will if the bolt stretchs and the head lifts....
mustangsally93
281
Omaha,NE
Apr 9, 2006
#35
  • Apr 9, 2006
  • #35
Well this morning I missed with it more. Also Im back in kansas so a freind is taking my heads to a shop to find out if those are all right for sure. Then this weekend I'm going to use oem head gaskets and arp head studs. I know the rings were fine because I used a feeler gauge. And if the heads come out fine it has to be the head gaskets or the head bolts?? Right?
CRASH7772
401
NH
Apr 9, 2006
#36
  • Apr 9, 2006
  • #36
mustangsally93 said:
How do I adjust the rockers??? We don't know how to..
http://www.fordracingparts.com/download/instructionsheets/FordInstShtM-6564-All.pdf
mustangsally93
281
Omaha,NE
Apr 9, 2006
#37
  • Apr 9, 2006
  • #37
thanks I well use that next weekend
J
JRPony
83
Las Vegas, NV
Apr 9, 2006
#38
  • Apr 9, 2006
  • #38
TTY bolts are designed to stretch. This is what happens when the they are angle torqued. And the head will not lift during a compression test.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Apr 10, 2006
#39
  • Apr 10, 2006
  • #39
All bolts stretch thats why its a clamping load,there like springs.
A TTY bolt once stretched doesnt return to its noraml length though,and looses some of its strength,making is useless...
If it lifted during running though,you already have a weak gasket.
mustangsally93
281
Omaha,NE
Apr 10, 2006
#40
  • Apr 10, 2006
  • #40
Well what do you guys think about this? Right or wrong?
  • 3
  • 4
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
