What year GT40 lower?
  • Thread starter Thread starter pissedoff92
  • Start date Start date Apr 30, 2012
pissedoff92
288
western new york
Apr 30, 2012
  • Apr 30, 2012
When I bought my cobra intake it was a legit 93 cobra upper but its a cheap chinese lower with the small oil baffle. Im worried that I'll get it all together and it will start using oil. So I'm gonna go to my local ford bone yard and scoop up an exploder intake. I will still be using EGR so what years would work for my setup? The car itself is a '92
stykthyn
5,232
2,652
223
gainesville
Apr 30, 2012
  • Apr 30, 2012
96 explorer
foxna6
143
aberdeen MD
Apr 30, 2012
  • Apr 30, 2012
96 or early 97 I've never heard of oiling problems with the Cobras though
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 30, 2012
  • Apr 30, 2012
Why not just change the oil baffle?
pissedoff92
288
western new york
May 1, 2012
  • May 1, 2012
Ive heard that sometimes changing the baffle doesnt fix the problem. Im kind of confused as to how the baffle causes the use of oil to begin with if someone could explain it to me. If the bigger baffle will fix the problem do I just call ford and ask for a 96 exploror lower intake baffle and specify "the big one"? And foxna6 the oiling problem isnt with the original cobras its with the newer ford racing lowers. I thought it had to do with a casting flaw but apparently its something to do with the oil baffle on the bottom.
stykthyn
5,232
2,652
223
gainesville
May 2, 2012
  • May 2, 2012
The coil baffle on the Chinese repops sold by frp is ridiculously small and allows oil to be drawn through the Pcv.
pissedoff92
288
western new york
May 2, 2012
  • May 2, 2012
if the pcv sucks it in wouldnt it recirculate?
pissedoff92
288
western new york
May 2, 2012
  • May 2, 2012
and where do i find the large baffle?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 3, 2012
  • May 3, 2012
I would just order it directly from Ford. The Explorer lower, is the same casting as the Cobra. Just order the baffle out of one of those?
pissedoff92
288
western new york
May 3, 2012
#10
  • May 3, 2012
  • #10
arent they riveted on from the factory? how does one attach it
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 4, 2012
#11
  • May 4, 2012
  • #11
Another option is to install an air-oil separator and just run what you got.
If the PCV sucks in oil, it goes into the intake and is then drawn into the cylinders where it is burned off along with the air/fuel. Then you have blue smoke coming out the tailpipes.
Junkyard or watch the classifieds, sometimes GT40 lowers pop up for cheap.
They are press-in pins, IIRC. I've seen machine shops pull them out delicately enough that they are able to press them back in. If that doesn't work you could drill and tap the holes and run screws in there, but I would definitely be using Loc-Tite then.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 4, 2012
#12
  • May 4, 2012
  • #12
Go here:
http://www.stangnet.com/mustang-forums/threads/technical-thread-how-to-index.808661/
Then here:
http://www.stangnet.com/mustang-forums/threads/unmetered-air-through-oil-filler.642930/
http://www.stangnet.com/mustang-for...-oil-separator-and-or-supra-pcv-valve.620577/
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
  • Locked
SOLD 93 cobra intake manifold
  • Jimmer009
  • Jan 19, 2025
  • Engine and Power Adder
Engine and Power Adder Jan 22, 2025
Jimmer009
J
