racer_inboston Founding Member Feb 2, 2002 310 0 16 boston, ma Jan 27, 2007 #1 Jan 27, 2007 #1 I was just wondering, might be buying a used 2005 and would like to know if say the 99-04 wheels fit the 05?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,252 17,937 224 Massachusetts Jan 28, 2007 #2 Jan 28, 2007 #2 They will physically bolt on, but the backspacing is not as deep. As a result, they will stick out from the body past the fender
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet Jan 28, 2007 #3 Jan 28, 2007 #3 Mustang5L5 said: They will physically bolt on, but the backspacing is not as deep. As a result, they will stick out from the body past the fender Click to expand... +1 it is best to buy wheels made specifically for the S197s for the best fit.
racer_inboston Founding Member Feb 2, 2002 310 0 16 boston, ma Jan 28, 2007 #4 Jan 28, 2007 #4 Yes thank you guys, I believe i will be going with 20x10 out back with 45mm back spacing and 20x8.5 in the front with 35mm backspacing. perhaps lowering it with some h&r's and caster camber plates for proper alignement.
