whats my compression ratio???
  • Thread starter Thread starter juiced_94gt
  • Start date Start date Aug 1, 2007
juiced_94gt
1,143
Southern California
Aug 1, 2007
  • Aug 1, 2007
With a CHP 331 with flat top pistons, and AFR 185's with a 61cc combustion chamber using Fel-pro 1011-2 head gaskets??
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 1, 2007
  • Aug 1, 2007
It should say on the spec sheet chp should have sent with you. I'll guess around 10.0-10.2:1 with those 61cc chambers.
juiced_94gt
1,143
Southern California
Aug 2, 2007
  • Aug 2, 2007
too much for boost then huh?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 3, 2007
  • Aug 3, 2007
Call CHP real quick, they will know...
Or you can use a static compression calculator via a search on the web and type in the info. Piston cubic centimeters, compressed headgasket thickness (yours is .039"), the 1011-1's are .041., head combustion chamber size (61cc), piston in hole numbers, etc.
vristang
4,933
101
124
Seattle
Aug 3, 2007
  • Aug 3, 2007
Find a calculator that takes into account the volume from the top of the piston to the top of the first ring.
This will bring your number down a little, but it's more accurate.
I have an excel spreadsheet... pm if interested...
good luck,
jason
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
