A KB would tear the stock powder-steel rods apart. like gearbanger said I-beam or H-beams would work. Manley makes good rods for supercharging or naturally-aspirated engines. They have I-beams and H-beams that can handle up to 2000hp and 9500rpms. I doubt you're looking for anything quite that durable, I just thought Id throw that out there.
As far as pistons you should definetly go with forged pistons. Obviously you want to look for a piston for high compression. There are pretty much two different kinds of allows used in forged pistons (I think). there is 2618 aluminum alloy which is typically used for race or high-performance street engines, they can handle up to 35lbs of boost. the other is a high silicon allow called 4032, which is for high-performance street engines. According to manufacturer's specs it's breaking point is 10lbs of boost, but I've seen applications of as much as 15lbs. NOT sure about the lifespan of that set-up though.
So this might have been information overload. Obviously I've been researching for my own build-up. Hope it helped out.
