Internet dropped out yesterday silver....and now SCTs site looks froze. No new posts since last month and it wont let me attach my datalog
Damn, that sucks. Well you can email it to me directly if you want-
jsbelisle@gmail.com
their fragile but not all that fragile, just ceartin things are not good for them. moisture will kill them quickly thats why they recomend mounting them at 3 or 9 o'clock on the pipe. also its best to have it places as close to the header collecter as possible to get more of a true readingIs there a better replacement sensor I can get? I mean, if this thing is this fragile, I will replace one every six months at this rate. What Wideband do you guys run? I got the AEM because I heard from several people it was very accurate and cheap...
And if I fouled the sensor, do you think I fouled my 02s as well? I have an extra set of those
Ands its lean ---. it has the LEDs around the edge, and when it goes --- the leds are on the lean side.
Can I email someone this file and have it analyzed? I think I am maxing out the fuel pump, this is some of the data-
PRES_DROP_F_INJ
90
RPM
5942
RTLS_FPUMP_DTYC
.677518
I lost traction, and traction control kicked on somewhere in there. This was after teh trac control for sure...
Maf ad count = 950
RTLS_FPUMP_DTYC= .9999998
PRES_DROP_F_INJ= 46.60352
RPM= 5813
Anyone have any input???????
Log sent Silver...its a short log. About 500 seconds and nearly 10MB.
I'd start checking the fuel system, starting with the rail sensor, it may have failed - they do fail on forced induction cars, in fact we tell our customers to always carry a spare. But usually when they fail, the car stops.
Well, it was 35* outside and the pull was in second gear up to about 55mph or so. Unfortunately I am just starting to learn about fuel systems.... what is the FPDM, and where is it located?
In my datalog I was also looking at my LTFT and STFT's, and at WOT they do look pretty lean. When I tried to add fuel, it almost made it seem to run leaner @ WOT, is this because I Was then maxing out the pump sooner?
What MAF are you running??
