whats wrong with my car?
  • Thread starter Thread starter 85cleangtvert
  • Start date Start date Jul 6, 2008
85cleangtvert
103
Jul 6, 2008
  • Jul 6, 2008
car in question is my 91 GT automatic... the problem my car is having, is when i step on it, it falls on its face. like it is getting too much fuel, i hear it backfire through the intake. it runs good when driving normal or slowly accelerating it...but when i punch it from a stop , it doesnt go anywhere and when on the freeway it cruises good but when i step on it hard as if to pass someone or just go fast it doesnt go anywhere just sputters and backfires through intake if i step on it. very annoying...
so far i have changed the plugs, wires, fuel filter, 02 sensors, tps sensor. i am going to change the cap and rotor tomorrow just for fun. i have done a compression check and all the cylinders were 135+, not the best but it is 185K on the car. i did a vacuum check and that was good. i cleaned the iac . the timing is set at 10*. i put a coil on from my 88 mustang that is good condition. i checked the fuel pressure and it looks good it was like 45. i am going to put a MAF on that i know is a stock one, because im not 100% sure what the one on there is. it looks stock but the car came with 24# injectors so i guess it could be a stock looking 24# calibrated maf. i am also going to look and make sure my computer doesnt have some chip on it or something. what else do you guys think i should look for or do?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jul 6, 2008
  • Jul 6, 2008
I bet you the MAF is a stock MAF.
WHat mods are on the car to require 24's?
Have you run the codes?
85cleangtvert
103
Jul 7, 2008
  • Jul 7, 2008
the car is stock. when i bought it, it had 24#ers on it. i thought that was the problem so i replaced them with 19s. I am not getting any codes.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Jul 7, 2008
  • Jul 7, 2008
yep.
when i got my 80MM, it would run fantastic on part throttle, but when i stepped on it, it would stutter like crap. I found out that MAF needed to be rebuilt, after that, it ran fantastic!!!!
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 7, 2008
  • Jul 7, 2008
so when you hit the gas, it loses all power then right?
If thats the case I had the exact same problem. I replaced the fuel filter and then the fuel pump and now it runs beautifully
85cleangtvert
103
Jul 20, 2008
  • Jul 20, 2008
the maf was bad. i replaced it and it runs great now.
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • Mindseye007
  • Aug 16, 2026
Mindseye007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
