Wheel "hop"
  • Thread starter Thread starter NormD
  • Start date Start date Aug 17, 2006
N
NormD
27
  • Aug 17, 2006
Occasionally I get rear wheel hop. This is on normal takeoff. Anyone offer any common causes for this intermittent problem?
Thanks,
Norm
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Aug 17, 2006
  • Aug 17, 2006
Wheel hop isn't something that is normally intermittent.
To fix wheel hop here's a few things you can try:
- new shocks
- stiffer leaf springs
- new suspension bushings
- traction bars
- remove lowering/lifting blocks if you have them.
mfp4073
387
Hells Ditch, FL
Aug 17, 2006
  • Aug 17, 2006
- new shocks
- traction bars
chepsk8
2,203
Easton, PA
Aug 17, 2006
  • Aug 17, 2006
Take some weight off your right foot.......
G
gsxrken
206
Weschester County, NY
Aug 17, 2006
  • Aug 17, 2006
Maybe he means clutch chatter- that can be intermittent (only when cold, only when hot) etc
N
NormD
27
  • Aug 18, 2006
clutch chatter
yes, now that you point it out it seems to happen when hot. although the clutch and pressure plate are only three years old. is the solution replacing the clutch and pressure plate?
tks
Norm
MustangMatt1966
1,004
Orlando Fl.
Aug 18, 2006
  • Aug 18, 2006
tks
Norm
the solution might also be that there are "hot spots" on the flywheel or slight cracks, to solve this problem the best solution is to have the flywheel re-surfaced. I had the same problem and have never had a problem sense.
brianj5600
1,964
Middle TN
Aug 18, 2006
  • Aug 18, 2006
Wheel hop or chatter on normal take off sounds clutch related. Wheel hop when launching would be suspension.
68RCodeConv
345
Houston, TX
Aug 18, 2006
  • Aug 18, 2006
Lots of possible reasons for clutch chatter: bad flywheel, bad clutch, bad pressure plate, bad motor/tranny mounts, worn (sloppy) clutch linkage, worn clutch pedal support bushings, bad u-joints, weak rear springs. Primary cause is the use of a remanufactured clutch/pressure plate, followed by a warped/uneven flywheel BUT I have seen all the other factors cause clutch chatter also.
Wheel hop, on the other hand, is almost always traceable to rear spring wrapup. Weak springs are the primary cause, but using air shocks (which unloads the springs) can cause it also. Stiffer rear springs and/or a good traction device (like Caltracs) will eliminate wheel hop.
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
