I have done my homework on wheel spacers, and I am trying to get my stock Bullitts to sit as close to the quarter panel as possible. And I do not want to purchase H&R and Eibach Spacers for twice the cost as here;
They say they are hubcentric, and are not some cheap bolt on spacer that isn't although they are much cheaper than the name brands. Would they be worth it or should I just save up for Eibach or H&R or DD Bullitts?
Those are NOT hub-centric. I have a set identical to them that I was going to use until someone told me the weren't hub-centric. When you look at the hub where the wheel sits, you'll see a lip on it. Where the wheels mount to the spacer, there's no lip. That lip is what makes them hub-centric. Take a look at these Eibach spacers. You can see the "lip" on the outside in the center. This is identical to the lip on the hub of the car, making them a true hub-centric spacer, not some cheap knockoff. Eibach Wheel Spacers 25mm (1 inch) - 1 pair - StangSuspension.com
On a different note, I have talked to several that have ran those spacers without problems, but it's not something I want to risk.
Not something worth risking on the rear where your power is being applied. Those aren't hb centric, they all say that now-a-days just to sell more. Even the 1/4" ones says it and you physically cant makes a 1/4" or 3/8" hub centric spacer, 1/2" and up and 1/2's require longer studs in stock position.
I dunno if it'll help, but here's my how-to: YouTube - How to install 1" wheel spacers and new wheels
