Wheere is the computer?
It's in the kick panel of the pass side. Remove it and there will be a plastic piece over it. There are also 2 connected harnesses that may have to be unplugged to remove it. I dont remember the EXACT layout once you're in there because of my TwEECer. Nevertheless, that's where it is!
Good Luck
RC
Hey guys, if you do a Auto to T-5 swap, is the computer swap a must? I've got a 347 in a ford ranger, with 95 Mustang controlling it, but I took it the stuff out of an auto, and my truck is a manual...and I'm having real issues... What would haveing the Auto PCM in a manual do?
I'm not an expert and have never swaped trannys before. I'm pretty sure you need a manual pcm with the manual tranny though. That could be the cause of your problems
If your issue is that the car randomly bogs for a second, it's likely the EEC. When the Auto EEC knows it needs to shift, it pulls timing. That's fine till you're no longer shifting at those same thresholds (because you now shift when you want to).
A used PCM is the same price as a unit from Autozone or Advanced. I did a conversion for a buddy last year and he got his from Autozon for 115$. By the time you get one from Ebay and have it shipped, you spend the same or more.
Also, they accepted his auto computer for the core! You need to find computer number: T4MO
Autozone will most likely have to order it for you, so when it comes in, make sure it has that number on it.
Thats good to know. I wonder if they have one for my Ram. Ebay has one for 189. I'll have to check Advance
Yep, it does randomly bog, and does it 2-3 times, likely attempting to shift the trans...
Big thanks for the code too The_Mustang, i was going to have to go to a friends, pull hers, get the code, and re-install it...:D
