Other than where the stock oil pressure sending unit is mounted, where can i found another spot to tap into to hook up an aftermarket pressure gauge?? If anyone has any pictures that would be cool. Thank you :SNSign:
You can also remove the hex tube that the stock sender goes into, and tap the tube for a fitting (for your second gauge). Just be sure it all fits together with enough clearance (this method works better for mech gauges).
If at all possible id like to keep the stock gauge functional. I just dont like looking at the dash and seeing gauges that dont work. Its not really a big deal though. just want to see if there are any other options besides doing away with the stocker. Thanks for the replies
just make a custom gauge bezel like this or go to www.florida5.0.com and buy one and put all aftermarket gauges. make it look good, no more tacky stock gauges that don't work.
Just use a T-fitting and put it in the stock location.
I beleive you'll need 1/8 NPT. I just bought a 2" nipple and a t-fitting. I screwed the stock sender into 1 part of the t and the autometer fitting in the other port.
