9 95StocK50 New Member Dec 19, 2002 398 0 0 Idaho May 8, 2004 #1 May 8, 2004 #1 where does this sensor go when you swap to this setup? My 93 down powerpipe does not have a fitting for this? thanks nathan
OrangeMustangGt Founding Member Mar 7, 2002 1,976 0 36 Cape Cod, MA May 9, 2004 #3 May 9, 2004 #3 i dont think 93-older even has the iac sensor.
9 95StocK50 New Member Dec 19, 2002 398 0 0 Idaho May 9, 2004 #4 May 9, 2004 #4 no not the idle air control valve, maybe i'm off on my abbrev. to but the one the screws into the intake tube .... i think its IAT, inlet air temp.... thanks nathan here's the pic, its the one right above my maf. View attachment 525571
Redsnk95 Founding Member Feb 3, 2002 2,243 1 0 Houston, TX May 9, 2004 #5 May 9, 2004 #5 93-down cars IAT was located in the #5 runner on the lower intake. I doing the 93-down stuff as well and I will be putting my IAT in the rubber coupler that connects the meter to the pipe. Troy
9 95StocK50 New Member Dec 19, 2002 398 0 0 Idaho May 9, 2004 #6 May 9, 2004 #6 hey thanks troy i'll do the same with mine.. nathan
