  • SN95 4.6L Mustang Tech
Where is it coming from?
  • Thread starter Thread starter streethorse
  • Start date Start date Oct 11, 2010
streethorse
1,042
Dallas Texas
Oct 11, 2010
  • Oct 11, 2010
Just started noticing a small puddle of water/coolant on the garage floor
in the morning. So I look everywhere for a leak, no signs on the topside
of the engine or near the radiator. I look under the car and see droplets
on the sway bar. where is this coming from? It only leaks after the engine
has been turned off for a while. And not much.
streethorse
1,042
Dallas Texas
Oct 11, 2010
  • Oct 11, 2010
Just checked the heater core in and out......dry as a bone, no leaks.
Is it posible for water to be leaking into the valley and draining out the back.
Ive checked out everywhere I can see with a flashlight.
D
darkside03gt
851
Sacramento CA
Oct 11, 2010
  • Oct 11, 2010
Take a good look at the coolant/oil filter adapter on the driver side of the block where your lower rad hoist connects. The gasket may have gone bad or the adapter may have cracked. Also see if you can get a mirror under your intake and check the coolant tube.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Oct 13, 2010
  • Oct 13, 2010
maybe your wife is fuggin with you, have you been doing all your honey do's ?
streethorse
1,042
Dallas Texas
Oct 13, 2010
  • Oct 13, 2010
No cant be that... Ive got 2 ex wives and they cant get into the garage.
But whats weird... is it leaked for 3 days, I added about a half gallon of water
and the last two days it hasnt leaked a drop.
joshjwc9
1,095
17
39
Palm Harbor, FL
Oct 13, 2010
  • Oct 13, 2010
Condensation? Are you sure its coolant? Any recent work done to the car?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 13, 2010
  • Oct 13, 2010
If it is clear water it is the AC drain line and its normal operation.
streethorse
1,042
Dallas Texas
Oct 13, 2010
  • Oct 13, 2010
Yeah It is defenatly coolant. And it did run low.
I had a brake job done 2 weeks ago.......hmmmm.
aar0s
1,015
55
69
Oct 13, 2010
  • Oct 13, 2010
water pump?
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
Issue please help
  • 4.6andre
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
Water leak from hatchback door
  • jeremyzcook82
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
jeremyzcook82
