right side in the middle of the cam cover, hope you bought an OEM Ford one![]()
right side valve cover???? driver or pas side???? whats connected to it?
i need details..im kinda retarted. o and yea I got the ford one Part# D9ZZ-6a666-a
well, you got the wrong one as the D9ZZ-6A666-A fits 2001 back.
2002 up Mustangs use a 1/4 turn/twist-in one and the part # for the "pre-heated" PCV valve is 2C5Z-6A666-AA or for a Non-heated one its 2X4Z-6A666-AA
oh and the rightside is the passenger side of the car
ok thanks!
you would think that if one went to a ford dealers parts counter and asked for a PCV valve for a mustang GT..they would give you the right part... Apparently ford dont know there cars parts. Randy? can u get me one?
i know you from Mustangboards.com
but Im starting to hear this alot more
do you want the $30.00 pre-heated one or the $10.00 non heated one? and I'll have to order it, about 1 day togetwell I can't speak for my "counter-parts" in this businessbut Im starting to hear this alot more
we sure can order one if you likedo you want the $30.00 pre-heated one or the $10.00 non heated one? and I'll have to order it, about 1 day toget
I would like the NON heated one. let me know if your need anymore info.
nah, Im good. I'll try and have one here tomorrow. will keep you posted![]()
Not to hijack, but whats wrong with a non Motorcraft one? I bought a Purolator to replace mine.
I have to ask, whats the difference between heated and non-heated?
aftermarket ones are not made to Ford spec's and can have a larger orifice which draws more vapor's and clogges-up the IAC and fills the lower intake wth a oily mess
p.s. ST your PCV valve is here, give me a call when you can
well, heat![]()
somewhere along the lines the Wiz Kids in Dearborn had a problem wth PCV valves frezzing-up in cold climates and thought the whole counrty needed to have pre-heated PCV valves, total BS if you ask me
well, heat![]()
A call? ok whats the #???
is it okay to replace a heated one (Im assuming 04s have heated) with a non heated? as you can see from my local, i have plenty of it.
well I can't speak for my "counter-parts" in this business![]()
