  • SN95 4.6L Mustang Tech
where should i start beefing up?:
  • Thread starter Thread starter toddlow
  • Start date Start date Oct 30, 2005
T
toddlow
11
  • Oct 30, 2005
2002 gt all stock except for flowmasters. what should do next
blue46gt00
83
  • Oct 30, 2005
If you have the money get a supercharger. Modular Power House makes a great kit. But if you don't have that kind of money I would say start with gears. I love my 3.73s.
road rage
433
R.I.
Oct 30, 2005
  • Oct 30, 2005
I agree, go with the gears. just had mine installed a couple of days ago. Also check out a nitrous kit!
40th GT
916
Lawrenceville, GA
Oct 30, 2005
  • Oct 30, 2005
Build up the rear end assy. if you are planning to run slicks/drag radials.
The Mustang's suspension definitely has lots of room for improvement, so I'd consider that too.
And as stated above, SUPERCHARGER.
The short throw shifter, tires and gears are also good investments.
M
Mustanggt108
221
  • Oct 30, 2005
x2 for the gears.If your planing to go FI go with 3.73 ,you'll love em.
If you got enough $$ check out the mongoose kit at modularpowerhouse.com
BennyBlown2v
1,233
Carmel, INdiana
Oct 30, 2005
  • Oct 30, 2005
Suspension! Haha, really, it all depends on what you want to do. Corner carve? Drag? Street car?
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Oct 30, 2005
  • Oct 30, 2005
Gears,a mid pipe,tune.
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Oct 30, 2005
  • Oct 30, 2005
Corner Carving>Drag Racing
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 30, 2005
  • Oct 30, 2005
depends, what setup/goals do you want?
Fast02
239
#10
  • Oct 30, 2005
  • #10
"Beef up" as in weak points of the car?
The stock shifter should be the first thing to get swapped out because if you start speed shifting and banging gears you could bend a shift fork using the stock shifter as it does not have stops as the aftermarket shifters do. All the aftermarket shifters are just about as good as the next. I have the MGW and like the progressive springs.
The next weak link has to be the upper/lower control arms that hold the rear end in place. Have you noticed the side to side action from the rear when you get on it?? Pick up an adjustable lower control arm. Also you may want to install a set of Subframe connectors to stiffen up the body.
Next would be a brake upgrade.
Happy modding,
Fast02
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 30, 2005
#11
  • Oct 30, 2005
  • #11
beef up your wallet first, youll need it
snGTstang
58
maryland
Oct 30, 2005
#12
  • Oct 30, 2005
  • #12
truest statement ever to be told on stangnet
T
toddlow
11
#13
  • Nov 1, 2005
  • #13
just looking for a awsome sounding fast car. Not to fast, i don't plan on dragging it or anything, maybe on test and tune nights. when i go to take off i want peoples heads to turn because of the mean sounding exhaust. thats about it i guess
O
OxMox
turkeysammichesonhisface
Mar 31, 2005
Palm Harbor, FL
Nov 1, 2005
#14
  • Nov 1, 2005
  • #14
CAI
Mid pipe (h or x)
short throw shifter
gears
lowering springs
cams
tune
stangGT97
1,299
Boston area, MA
Nov 1, 2005
#15
  • Nov 1, 2005
  • #15
forget the CAI... and also, the TR3650 in your 02 GT has integrated shift stops so you dont have to worry about bent forks when bangin the gears with the stock shifter. i would definitely recommend a set of gears, some sort of x/h pipe, and a catback. look on mustangexhaust.com for sound clips of various midpipe and catback combos. I can tell you from experience that an O/R H and 2 chamber flows sounds like retro-muscle, and my current catted X with SLP loudmouth 1s is very loud and racy, and makes people crap their pants
drag0nfan's04GT
58
Sierra Vista, AZ
Nov 2, 2005
#16
  • Nov 2, 2005
  • #16
yep, I was ass backwards when i worked on my car. I didn't know much when I got it. I just had the gears installed which I should have done first. I did the catback, K&N, TB/plenum, then the pullies, then the h-pipe, and finally the gears. That was mainly because of when I had and didn't have money, and what I could find for the best price at the time. It's all done now, but I would have probably went with gears, mid pipe, catback, and tb/plenum last. The K&N and pullies could have went anywhere in between. I've got a tuner and springs in the mail.
BooWFO
991
Louisville, KY
Nov 2, 2005
#17
  • Nov 2, 2005
  • #17
Ok based off what you said. Get an Offroad midpipe, and Mils. and some dumps (either flowmasters mac's something along that line) The Magnaflow's sound great with an OR xpipe, and not lot's of people use it. The 1 chamber flows are stupid loud so is the borla stinger series too loud IMO for a streetcar.
Now for mods that will help you. gears for sure, I'd suggest at least doing a bearing kit when you do them and if funds allow go ahead and build the rear end, good axles, better diff, cclip elim's. You don't want to be the guy who snapped his axle. For drag tires get some 15" Dr's or slicks and have fun.
For more power nitrous is cheap and easy, but a blower is always there.
Anything on the chassis helps, IMO SFC should be the first mod everyone does, then gears. Control arms also help tons.
Also search the forums you can gain lots of wisdom and hopefully spend your money wisely.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
