Where to buy a Idle Air Control?
I bought mine straight from Ford. A little over 100 bucks but worth the extra cost so you're not shooting yourself in the foot with a POS discount store IAC. I figured mine lasted over 100K miles, so it'll be worth it if this one does too.
I had an IAC go bad, so I made the mistake of buying a POS autozone replacement and it was already a broke ass pile of crap when I put it on. I went to the junkyard, and found 3 for 8 bucks a piece, one of which was brand new OEM Ford replacement.
Buy **FORD ONLY**, for
o TFI
o IAC
o EGR
O TPS
Otherwise, save your time and just me the money you'll be wasting on some POS aftermarket part. :) Mustangs Unlimited is very good about having FORD stuff in stock and being able to ship it out the same day (?order before 2pm?). Also, check other companies.
http://mustangsunlimited.com/
Rockauto is also good about having a number of FORD parts:
http://rockauto.com/
And, don't forget Summit
http://summitracing.com/
And, so on.
Note: Buy FORD ONLY IACs and EGRs because they are subjected to a lot carbon from the EGR system. Buy a FORD TPS because it's NOT easy to make a weather-proof TPS that doesn't get flat spots. Buy a FORD TFI because it's subjected to a LOT of heat and vibration - the after market POS units have a tendency to doe quickly.
It's *your* money. All I can do is tell you how to spend it wisely. :)
