my are from Lamin-X,
anyways i used a water/soap mixture,
I first cleaned the lens with windex, then with alcohol wipes i wanted to make sure they were real clean,
I then sprayed on the water/soap mixture and then aligned the yellow clear film, and used one hand holding the film the other to remove the water, with a flexible plastic tool (i don't know what its called but a credit card would be good too)
I remove most of the bubbles, and let it dry out in the HOT sun for hours,
and thats it,, don't use windex on them after the installation for cleaning,
you will notice a few bubbles after you remove all the bubbles that you can, these will become smaller or disappear after you let it dry, after it dries it will be around 95%(+-) bubble free, you can only see the bubble when u look at them directly
if u need any help i will be glad to answer your questions
