that wire goes to the + side of the coil and is resisted to 9v though. I need to figure out where to mount the power wire for the duraspark ignition box.brianj5600 said:The 3 wire plug that has water and oil sensor wires also has the ignition hot wire.
DarkoStoj said:that wire goes to the + side of the coil and is resisted to 9v though. I need to figure out where to mount the power wire for the duraspark ignition box.
is that the brown wire that goes to the I terminal on the solenoid?LMan said:you can also run the wire to the solenoid near the battery (switched 12VDC)
DarkoStoj said:is that the brown wire that goes to the I terminal on the solenoid?
I checked mine this morning with a V/O meter. Key on motor off = 12.68 volts. Mine is a 6 cyl car. Could that make a difference? I have not fired mine yet, but that is wired to my MSD box, I hope it works.DarkoStoj said:that wire goes to the + side of the coil and is resisted to 9v though. I need to figure out where to mount the power wire for the duraspark ignition box.
