wheres my oil sensor 96 gt?
im so confused....haha..randy says there is a low oil sensor and then he says theres a pressure sender....so is it the same thing or what?...the only thing i could find is the piece you guys are talking about next to the oil filter....
Is the oil pressure sensor differant that the low oil sensor?
ok, let me explane.
all the modular engines have a "Oil Pressure Sender" for the gauge in the dash and the "SENDER" is located on the oil filter housing.
the LOS (low oil sensor) used ONLY on 1996 V8 Mustangs is located on the driverside of the engine oil pan. this "SENSOR" trips a low oil light on the dash when the engine gets @1qt low. if you engine is topped-off wth the right amount of oil and the LOS light is still on, the "SENSOR" is bad and should be replaced.
ok, let me explane.
Ok thank you..i will see If I can find it on the oil pan
Ok thanks... I see it...haha..had to go behind the front driver side tire to see it...How much is this sensor?...my low oil light comes on all the time and I check the oil and the levels fine..so I should replace this right?
sensor and gskt/o-ring is @$30.00 from us + shipping, out of and @ 1/2 days toget
here are the part #'s if you want to try locally first.
sensor F2AZ-6C624-B
o-ring/gskt E9DZ-6C626-B
