Whew, just bought alot of stuff!
Joe 5.0
1,184
Macomb, MI (metro detroit)
Gettin all the parts to go along with my s-trim install. Here's what I just dropped $1000 on:
Crane HI-6 w/Direct Plug-In harness
Crane LX-92 coil
Crane 8.5mm Firewire plug wires
NGK 7373 Plugs (FR-5, one step colder than stock)
Snow Methanol Stage 1 kit, with 7qt container & low level indicator
4 cases (16 gallons) of Snow Boost juice (pre-mixed 50/50 meth/water)
3.00" Vortech Renegade pulley
:eek: :flag: :hail2:
500+rwhp here I come. :drool:
Sweet. I am pretty interested to see how your combo does. I wouldn't think you would have any issues getting well above 500 rwhp out of your combo.
If you are going to run the 3.00" supercharger pulley, what size pulley on the crank do you plan to run?
From what I understand the ONLY difference between the stage 1 & stage 2 is the variable controller. Basically with the controller you can start the meth at say 3psi, then as boost increases the amount of meth increases until you hit peak boost. I guess it makes better low to mid range power, but at WOT they are just about the same. The stage 2 has the same nozzles, the same pump, and the boost switch. I can always buy the controller down the road for $125, and still be cheaper than the stage 2. The reason I got the stage 1 is cuz they went on sale for $219, down from $290.
And I got the boost juice from Summit (I got everything through them, cept for the low level switch). They are the same price as directly from Snow, but the free shipping makes it a MUCH better deal.
And yeah, the Crane HI-6 had better specs than almost every igntion (esp the 6AL), and it cost less. Plus it looks a helluva lot nicer. Even the Firewire plug wires seemed better (lower resistance, and better heat protection) and cost less than the MSD's.
