95COBRA241 said:
I hope I don't get owned. lol, but it is my understanding that the MAF calibrations for a GT and a Cobra are both set at 19lbs. The Cobra pcm adjusts the MAF reading (signal) for the larger 24lb injectors.
Also, am I correct is saying that the T4MO is for auto and the J4J1 is for manual GT's? What is the code for the Cobra computers?
j4j1 is for the Cobra only
t4m0 can be found in stick GT's
and
I think they came in stick GT verts also.
See if this helps the confusion about mafs
Ford doesn't cal their mafs in the same sense as you usually think about ProM caled mafs for various size inj's.
It is true that the GT & Cobra use the exact same maf.
a) The GT pcm has an inj size value of 19
b) The Cobra pcm has an inj size value of 24
a & b is the main difference between the cars pcm files in this case.
It is true that the maf curve is different between the two cars but it is not much different. Not enough to make any fuss about.
Mafs are about air flow ...... not inj size. With that being said ...................
While the Cobra makes more power than the GT, the additional air flow the Cobra generates is not so much that the GT maf and maf transfer can't be used.
however ................................
The same additional power that the Cobra makes did cause Ford engineers to see the need for the larger 24lb inj's.
This is a perfect time to point out that for a lot of combos..........................
you run out of inj before you run out of maf (pegging the maf)
Later
Grady
