Which engine will work?
  • Thread starter Thread starter RedStang88
  • Start date Start date Apr 29, 2004
R
RedStang88
188
  • Apr 29, 2004
The head gaskets on my 94 3.8 went and I it will cost a few hundred just for parts if I do the work myself. So I am thinking of putting a v8 in it. I have been told that I can use the v6 tranny and rearend for now, they just arent as strong. What I want to know is which of the following will go in the easiest. I can get a 5.0 motor from an 87-95, I believe they are the same, and all I will need to change is the computer and a/c something, right? I can also get a 4.6 from a 97, is that hard to work with? I believe I will also need the intake from both of these. Any others suggestions just let me know thanks.
blk9450
1,507
your moms bed
Apr 29, 2004
  • Apr 29, 2004
eh i dont know about the trans, i wouldnt use it, but im almost positive that the rear on the 94 up v6 is an 8.8" which is the same as the 94-up v8.
R
RedStang88
188
  • Apr 29, 2004
What about the engine parts, can I use the alt, power steering and starter from the six?
R
RedStang88
188
  • Apr 29, 2004
Alright, I can get a motor from a 94 with a 5.0 in it. The guy says it doesnt come with the power steering pump, alternator, and starter I believe. So what else do I need to make sure I get to complete the swap?
R
RedStang88
188
  • Apr 29, 2004
ttt
dastang2
2,020
tx
Apr 29, 2004
  • Apr 29, 2004
motor mounts and exhaust, the v6 accessories will work and you need a v8 radiator probably plus the computer and harnesses
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 29, 2004
  • Apr 29, 2004
I dont see how its going to cost a "couple hundred" just for parts to change a head gasket. All you need are head and intake gaskets which shouldnt cost more than $75 and a weekend to install them.
As far as the cost of a HG change vs. a V8 swap, just change your gasket. The cost, time, and effort of an engine changeover is alot more than keeping what you have. Not only that, your car will remain more valuable and will be easier to sell down the road.
R
RedStang88
188
  • Apr 29, 2004
I priced gaskets, they were 65-80 dollars, and they have to be sent to a machine shop, so thats another 220-250 dollars. I found a few engines for 400 to 500 dollars.
65ShelbyClone
4,675
38
119
Apr 30, 2004
  • Apr 30, 2004
Huh? How is a machine shop even involved? Go to Pep Boys and get some Felpro gaskets or if you live painfully far out in the sticks, order online or something. Also, you may be able to get an engine for 400-500, but its going to cost a hell of alot more than that for all the parts needed to make it work. Factor in an 8.8 rear and V8-spec T5 down the road too.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
