Which fuse?
I am preping my car for the supercharger and was wondering if anyone has done anything with there traction control, I am going to try and get a hold of Kenne Bell and have them disable it, but if for some reason they can't is there a fuse to pull. I have looked in owners manual and the fuse that they say is used for "traction control switch" also runs the the gauge cluster, Is there another fuse or another way. I know this was brought up before and someone mentioned an inverter. Does anyone know anything about this or have part #. I wouldn't mind it if it would stay off, I could just unplug the switch so it couldn't be turned on. Thanks in advacne. :shrug:
The traction control is part of the ABS control unit. There is no fuse dedicated to the T/C switch. Even if there was, it would just disable the switch, preventing you from turning off the traction control (it automatically defaults to "ON" each time you turn on the ignition).
Several companies sell a module that simulates manual operation of the T/C switch each time the ignition is turned on, effectively giving you a "default to OFF" capability. For links , do a Google search for "Mustang traction control disable".
