which intake do you recommend?
  • Thread starter Thread starter dmc919
  • Start date Start date Feb 2, 2011
D
dmc919
41
  • Feb 2, 2011
doing a hci on my mustang, going with tfw fac 190 heads, tfs stage 2 cam, not sure what intake i want to run, here's what i'm looking at. I would just go with the biggest but not sure how much a big intake will effect drivablity. this is going on a stock bottom 302 with future plans of a 351w.
tfs track heat 1,500-6,500
tfs r series 2,500-7,250
holley 2,000-6,500
edelbrock performer 1,500-6,500
edelbrock victor 4,000-7,500
9
90stang5speed
582
Columbus Ga
Feb 3, 2011
  • Feb 3, 2011
If you plan to up grade to a 351, keep in mind that a 302 intake wont fit the 351. Its not the biggest and badest but, If you want to do a 351 later, I would just throw an explorer intake on there from a salvage yard for now. it would be cheap as you would be bying another intake when you do the 351 and, from what I hear, they can flow enough air to support 350 crank HP.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Feb 3, 2011
  • Feb 3, 2011
system max... when you go 351 get a 351 truck lower and gasket match it to the system max...
D
dmc919
41
  • Feb 3, 2011
I already got a truck lower for the 351 so that would be nice, think it will flow enough tho?
srtthis
5,129
1,666
204
Maryland
Feb 3, 2011
  • Feb 3, 2011
should be fine... for that head combo on a 351
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 3, 2011
  • Feb 3, 2011
302 parts make 302 power. Remember this if you plan on putting these parts on a 351 based engine down the road.
Doesn't the Trick Flow R use the same upper on the 302 and 351 models? That might be something to consider, then you'd only have to change the lower when going to 351. I think the Victor may be the same way, not sure though.
clement
1,104
52
59
Oak Cliff
Feb 3, 2011
  • Feb 3, 2011
w/ that cam, heads and displacement put a tfs track heat on it. if you dont youll be bitching about the lack of low end power. if you change the cam to a custom grind you can go ahead and put like a tfs r or spyder or whatever on it.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,231
2,929
224
Vass, NC
Feb 4, 2011
  • Feb 4, 2011
you will not run out of air with a TFS-R whether you put it on a 302 or a 408. It's going to hurt low-end on the 302, though.
clement
1,104
52
59
Oak Cliff
Feb 4, 2011
  • Feb 4, 2011
not if the valve events are right. but the valve events on a tfs stage 2 are not right unless you want the 302 t0 turns around 7500 with that large cross section head and intake.
FastDriver
Sep 5, 2001
6,231
2,929
224
Vass, NC
Feb 4, 2011
#10
  • Feb 4, 2011
  • #10
Agree to disagree then clement. I don't believe you can make up for tuned runners with cam timing.
clement
1,104
52
59
Oak Cliff
Feb 4, 2011
#11
  • Feb 4, 2011
  • #11
you can create more velocity in the port by making the intake valve opening point happen later. like ATDC. but if you do this a good set of heads is a must. "tuned runner", thats a good one.
FastDriver
Sep 5, 2001
6,231
2,929
224
Vass, NC
Feb 5, 2011
#12
  • Feb 5, 2011
  • #12
it wasn't a joke, and as already stated, I'd prefer not to get into a drawn out discussion on this because I can see that I would lose interest in the argument fairly quickly. You're pretty set in your opinion and I'm not going to change that. Thanks for the valve timing lesson, though. Now, look up Helmholtz tuning and then get back to me on how your intake valve timing event is going to make up for the resonance waves supercharging effect.
The fact of the matter is that a short-runner intake like the TFS-R is "tuned" - yup, there's that word again - to take advantage of the resonance waves at high RPM whereas a long-runner intake like the GT-40 is "tuned" to take advantage of the same effect at lower RPM. Since neither the valve timing nor the length of the runners adjusts with RPM, there's no getting around the fact that a short runner intake is going to hurt low RPM torque. I'd love to see any evidence you actually have to the contrary such as the same 302 combo with a comparison of a short-runner vs. long-runner with their own custom cams specifically aimed at maximizing low-end torque.
clement
1,104
52
59
Oak Cliff
Feb 5, 2011
#13
  • Feb 5, 2011
  • #13
nevermind. it not worth arguing over like you said. im gonna go work on my car.
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
347 intake recommendations
  • Dmarstroker
  • Feb 3, 2010
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 9, 2010
NIKwoaC
  • Locked
TURN-KEY TURBO BIG BORE 347 DSS AFR 614 RWHP/657 RWTQ
  • speedshifter
  • Feb 6, 2011
  • Engine and Power Adder Parts
8K
Engine and Power Adder Parts Feb 27, 2011
speedshifter
L
408w which air intake?
  • liquid_02
  • Apr 24, 2008
3K
Fox 5.0 Mustang Tech Apr 26, 2008
347HO
