  • SN95 4.6L Mustang Tech
which kit do I need
  • Thread starter Thread starter screamin gt
  • Start date Start date Nov 5, 2008
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Nov 5, 2008
  • Nov 5, 2008
for a gear swap. already have the ring and pinion. I just need to know which one of these kits I should go with. have about 111,000 on my stock rear end.
Ford Racing, Ring and Pinion Gear Installation Kits - summitracing.com
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 5, 2008
  • Nov 5, 2008
Honestly with the amount of miles on your stock rear i'd probably get this one Ford Racing M-4210-C - Ford Racing Ring and Pinion Installation Kits - summitracing.com, and it may not hurt to rubuild the t-lok. Seeing as how your motor has been freshly rebuilt, you might as well rebuild the rear so you don't end up blowing it up after the gear install due to worn out factory pieces and then you'll end up paying for labor twice to fix it.
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Nov 5, 2008
  • Nov 5, 2008
I kind of figured that but I was hoping one of the cheaper ones would be sufficient. oh well. thanks man!
BurningRubber
1,865
24
58
Nov 5, 2008
  • Nov 5, 2008
That Ford Racing kit will be fine, I used the Ratech full bearing kit + axle bearings and seals and they are just fine.
Order an extra crush sleeve or two in case one gets damaged during the install. They are cheap and your installer will appreciate the gesture.
Go ahead and get the trac-lok rebuild kit while your at it; its $45 and will save you from cracking the rear end open down the road when it starts to wear out.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
