00BlackBeautyGT said:Mobil 1 5w-30 with Motorcraft Fl-820 here too. Engine runs so smooth.
smokin'Red35th said:why does everyone use 5W20? I use 10W30 only because that seemed to be the standard oil used in most vehicles. is there a certain benefit to 5 weight that i should know about? I run Castrol Full syn if that makes a difference.
Dark Knight GT said:There are two numbers involved with motor oil. The first one with the "w" has to do with its weight during the winter or its pour weight at freezing point. The lower the number with the "w", the better the oil flows when cold. The higher, the thicker it is when cold. You want as thin of a weight as possible in the cold so it will flow to the motor and lubricate it faster on start up and early oppertation.
