  • SN95 4.6L Mustang Tech
Which sensor is this?
  • Thread starter Thread starter d98gt
  • Start date Start date Apr 18, 2005
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
  • Apr 18, 2005
I believe on the left side it's the coolant sensor, but I accidently broke the one of the right (circled in picture)
What is it called and where to get and for how much?
A quick response is needed
blackstalion666
177
New Jersey
Apr 18, 2005
  • Apr 18, 2005
im almost certain thats the coolant sensor
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
  • Apr 18, 2005
The one circled would be on the drivers side.
If it's the coolant one, what is the other?
thanks
Get E Up 98
144
  • Apr 18, 2005
Hey D I was successful in making the intake swap on my 98 GT. Only thing I did was break the cable for the crusise control..lol But it was by accident and stupidity, other than that it took 2 1/2 hours to swap out. Putting it on was simple. Just taking the crap off was a pain. Ill post a pic of my old manifold and the crack in it when I find my USB cable for my camera
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
  • Apr 18, 2005
Yeah, I wanted to tackle my install earlier this week, though things came up.
Im working on removing the things right now and will probably call it a night due to me breaking this damn sensor
How did you do the fuel rails? Im not too far into my install
I need to find out the name of this stupid sensor so I can pick one up ASAP.
Get E Up 98
144
  • Apr 18, 2005
Well you are supposed to have a special tool to remove the fuel rails, but I made a custom tool to seperate the spring from the connector then pulled them apart, they were the biggest pain!!!!
G
green_fow_six
310
Martinez, CA
Apr 18, 2005
  • Apr 18, 2005
thanks
They are both coolant sensors. 99 and up did away with the drivers side i'm pretty sure.
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
  • Apr 18, 2005
I might be wrong, though one is different than the other? I don't know if they could interchange
Am I wrong?
Any general idea what one of these will cost?
also, are you positive it's a coolant sensor
CanadaStang
2,093
Mb
Apr 18, 2005
  • Apr 18, 2005
The one on the drivers side is the ECT sensor. It is for the temp gauge.
The one on the passanger side is the ECT sender. It sends info to the EEC.
They are not interchangable.
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
#10
  • Apr 18, 2005
  • #10
How expensive will a ect sensor be?
Hopefully not much
CanadaStang
2,093
Mb
Apr 18, 2005
#11
  • Apr 18, 2005
  • #11
Hopefully not much
Hmmm... good question, I would guess about $35.00
d98gt
4,505
59
204
SE Texas
Apr 18, 2005
#12
  • Apr 18, 2005
  • #12
Someone was attempting to tell me that it'd be around $150 but maybe that would be for the sender to the eec, and not the sender to the guage
I sure hope so.
My $200 project would nearly double if I had to buy a $150 part =(
d98gt
4,505
59
204
SE Texas
Apr 19, 2005
#13
  • Apr 19, 2005
  • #13
Do you have a picture of the bottom of the fuel rail or could you explain what type of "tool" I will need to pull the rail off
Im not at the car but will be soon, and figured I could get this done if someone could explain it
Get E Up 98
144
#14
  • Apr 19, 2005
  • #14
I took a zip tie, cut it so it fit perfectly around the round piece on the fuel rail connector, slid it into it. Kinda hard to explain. But if you examine it real well you will see what I mean. You have to seperate the spring lock from the end of the connector to allow it to free itself.
GDawg
1,469
Nevada
Apr 19, 2005
#15
  • Apr 19, 2005
  • #15
You remove the two lines labeled "fuel line connections" in this picture.
You use a tool that looks something like this. Mine came six to a pack and were different sizes and marked by different colors. I needed two of the tools, one for each connection. (You use the same tool for removing your fuel filter too). You can buy these at any autoparts store for somewhere around $10.00 for a complete pack.
d98gt
4,505
59
204
SE Texas
Apr 19, 2005
#16
  • Apr 19, 2005
  • #16
I have the tool for the fuel filter, so hopefully it will work
Thanks for the quick info. I shall go work on this some more
GDawg
1,469
Nevada
Apr 19, 2005
#17
  • Apr 19, 2005
  • #17
If it's any help, here are some pictures from when I replaced my intake manifold.
Click here for Webshot pictures of intake replacement... View the slideshow of it...
Get E Up 98
144
#18
  • Apr 19, 2005
  • #18
Nice slide show, im gonna post pics of my decimated old manifold when I get my camera cable.
d98gt
4,505
59
204
SE Texas
Apr 19, 2005
#19
  • Apr 19, 2005
  • #19
Alright, got the old out and will start putting the new in tomorrow. I've been taking everything slow and im not in a real hurry to get it finished.
There is a spacer that was on my factory intake which goes between the Plenum/Intake Manifold.. Should I put this on the new one?
I'll go ahead and change the plugs tomorrow since it's a clear shot to the passenger side back plug (usually hard to get to).
Injectors are a bit dirty, though i'll clean this up tomorrow also.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
