  • SN95 4.6L Mustang Tech
whine...........
  • Thread starter Thread starter jrc_03_gt
  • Start date Start date Jul 24, 2004
jrc_03_gt
786
  • Jul 24, 2004
I recently had a new tremec 3650 transmission installed and a set of 4.10 gears. The car has a whine when I lightly rev the motor in neutral but when I press the clutch in it goes away, Keep in mind I'm not in gear and I am not moving. So I took the car in to have them replace the throw-out bearing. The result is the same. Anyone have any Ideas what it might be??
killbee
96
Western NC
Jul 24, 2004
  • Jul 24, 2004
Does in stop when you just barley apply pressure to the pedal or do you have to press it all the way in to stop it? Light pressure=throw out bearing, full pressure=clutch, sometimes the throwout and or new clutch will make a slight noise when they are new but usually goes away after a few miles. I have had this happen to me twice in my last 5.0 but it went away both times after a couple of hundred miles and no problems even on the 500+ hp motor.
jrc_03_gt
786
  • Jul 24, 2004
It stops when I push clutch all the way in or when the rpm's drop back down to idle.
killbee
96
Western NC
Jul 24, 2004
  • Jul 24, 2004
When the clutch is in the tranny is disengaged from the flywheel. If it was the throwout bearing it would change tones when you just touch the pedal. Did they install a new clutch when you changed trannies? If they did, did they resurface your flywheel? If not this could be the problem if they did it sounds like something in the transmission. Just shots in the dark without actually hearing the noise.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
