  • SN95 4.6L Mustang Tech
Whining Nose?
  • Thread starter Thread starter mustangman9812
  • Start date Start date May 8, 2006
mustangman9812
661
Mars Hill, NC
May 8, 2006
  • May 8, 2006
When on the interstate in overdrive doing 60mph or more - when i hit the gas or let off something is makeing a noist from under the car. To me it sounds like my mufflers are rubbing the driveshaft and there are marks on my driveshaft, can that be possible or what could it be??
hobbes80
410
Northern Virginia
May 8, 2006
  • May 8, 2006
Universal joint going bad
the98stang
2,408
Clovis, CA
May 8, 2006
  • May 8, 2006
could be a U-joint, the gears, or your tranny
hell, even cupped tires can make whining noises
DTNODYA
831
  • May 8, 2006
+1 for the transmission. I don't know for sure but that's my guess. Not that anything is wrong with it necessarily. If you get bored or something, take out the center plastic console deal and then drive around. If it's the trans, it should be easy to hear. Reason I say that is because I took mine out to do some wiring the other day, ended up having to drive to the store and I could hear my trans making all kinds of funky sounds. (My TOB is gone though). My $.02
mustangman9812
661
Mars Hill, NC
May 8, 2006
  • May 8, 2006
i found it. My mufflers are rubbing my driveshaft. I had a custom flowmaster turn-down cat back put on, and he didnt bend the left side enough so it is sitting on my mufflers. I am deff taking it back to him to get fixed!
the98stang
2,408
Clovis, CA
May 8, 2006
  • May 8, 2006
glad it's not the tranny or rear end
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
W
intermittent start and rough, high idle. 06 gt
  • Woe06
  • Jan 7, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 7, 2026
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
