- May 28, 2011
- 15
- 0
- 1
Ok need your help once again Stangnet! So I got my car about a month ago. 1992 SSP Mustang coupe 5.0 5spd. The motor is stock, save for a E cam and a cone filter. It has stock headers with flowmaster 40s.
Last week the car was running great. Decided to take it to the track for test adn tune just for a base time. I turned the timing up to 12. Ran the tank down to about 1/4 - 1/8th tank of gas put in some 110 cam II. The car ran pretty good. No traction off the line and high in the RPMs I think I was hearing some pinging but I don't believe the timing was set to high. So I only make two passes and decide to quit for the night and check the timing when I got home. At this point the car is running good other than the pinging when I'm really on it. The car sat as I watched the other cars run.
So there is where it goes bad. I drive it home and start to get on it just a little bit and I have zero power past 3500 rpm. its like I am running out of fuel or something. I then filled it up with regular fuel (93 octane) and still the samething.
Today I pull the fuel filter, on a hunch, as I ran the tank low. The fuel filter doesn't look terribly old. I dump the contents and out comes milky white stuff. This stuff dries into a fine white powder, WTF?! So I replace the filter. Drive the car runs great. I double check the timing, it is 12. All good, decide to drive the car around alittle more and here we go again no power past 3500 rpm.
I haven't pulled the filter back out, but I can only assume it is clogged up again. So I am thinking I am gonna have to remove the tank and wash it out. I can only assume the filter sock on the pump is also clogged. Any suggestions greatly appreciated. I am also thinking I wanna replace the fuel pump. Not sure what to put in.
