white smoke at higher rpm's
  • Thread starter Thread starter 95StallionGT
  • Start date Start date Apr 12, 2008
95StallionGT
68
Cashville, Tennekkee
Apr 12, 2008
  • Apr 12, 2008
So recently I just noticed that when I get on it at around 3500 in forth, my car is blowing out white smoke, from what looks like under the hood on the right side(intake side). It puts off a burning smell too. Im thinking maybe a head gasket because its going through a heck of alot of coolant, but never overheats?
Any thoughts would be appreciated, shes my baby.
mustangfan1990
505
Lenoir, North Carolina
Apr 12, 2008
  • Apr 12, 2008
Well If the head gasket is blown and it is putting out white smoke then it would have to compressing it and burning it which then it would come out of your exhaust. If it is coming out from under the hood white then maybe it is blown from a water jacket to the outside. Therefore if you kept water in it then it shouldnt overheat
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 12, 2008
  • Apr 12, 2008
How does your coolant and oil look??
Do a compression test.
95StallionGT
68
Apr 12, 2008
  • Apr 12, 2008
Seems to eat through coolant here lately, and I know I have a small oil leak. Oil pressure looks good, sits between the "O" and "R" in Normal. Just changed the Oil a couple days ago and I just noticed that it looks like some of the spilt oil dripped down the H-Pipe. Stupid question but could I have put too much oil and its throwing some out, and onto the H? And its burning it there?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 13, 2008
  • Apr 13, 2008
Hmm...missing coolant?? White smoke??
You have a blown HG.
Do a compression check to be sure..but i'd start getting ready to pull the heads off
95StallionGT
68
Apr 13, 2008
  • Apr 13, 2008
Ehh, HG wasnt what I was hoping for.. Never done a HG before. Weekend job or should I let somene do it?
mustangfan1990
505
Apr 13, 2008
  • Apr 13, 2008
Well yeah its a weekend job or one day if you work all day but for someone that has never done it I would say a weekend job. Nothing to it really though. Take off the intake and the heads clean the gaskets surfaces on both the heads and the block. Put new head gaskets. buy some ARP head bolts with some moly lube and put the heads back on. Be sure to get a torque wrench and torque the heads right. Then put the intake back on ( dont tighten the intake too much or it will blow the head gaskets again) And nobody dont say it wont cause mine did. I tightened mine down to tight and blew the head gasket on both sides as soon as it got hot in the same place on both sides. anyway then I would let the car run for a minute or two with no water so the heads seal good and then add water..( oh yeah dont put sealant on the head gaskets
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
T
  • Locked
1990 2.3L automatic - real bad engine sputtering
  • the_steve_randolph
  • Jun 13, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2024
the_steve_randolph
T
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Engine White smoke out of tail pipes
  • sav22rem22
  • Apr 21, 2021
3K
Fox 5.0 Mustang Tech Apr 27, 2021
sav22rem22
Burning oil, white smoke on startup and heavy acceleration, and loss of acceleration when first going
  • T_Roberts
  • Aug 19, 2021
  • SN95 V6 Mustang Tech
4K
SN95 V6 Mustang Tech Aug 26, 2021
T_Roberts
