White smoke from exhaust...! Ideas anyone?
marine12001
9
My 2001 Cobra has 100k miles on it and the short block was replaced 3 years ago with a
KarKraft Aluminum short block.
Car started up and sputtered down and died. White gas smelling smoke was coming out of exhaust. Fuel and water is mixing some where.
-No water in Oil
-Coolant is fine
-Nothing leaking from underneath
-Car not overheating (Well didn't give it time to)
-No Knocking or obvious noises coming from engine.
Nothing up to this point gave me any indication something was wrong.
Im going to do a compression test in the AM.
What is the likely suspect?
-Cracked Heads
-Head Gasket
-Cracked Block
-Intake manifold Gasket
Compression and leak down test done
Results
Compression
110 160
45 150
60 150
180 140
Leak Down
20 20
20 20
30 20
20 20
Looks like it is the trusty right side head gasket. Ill be swapping it out this week and taking the Heads to the machine shop to get resurfaced.
