white smoke ok?
Burnouts said:
I just had an f303 cam installed and now there is white smoke coming from the exhaust is that alright its not that bad just alittle bit
Only if it's coming from your bong. :banana:
O.K. seriously, I would say no, but I'm no technical guru, although there are tons here that are. Just hang around and I'm sure someone will give you a better answer than I did. :D
Just to clarify, No, it's not a good thing. Especialy if it wasn't doing it before the swap. Sounds like you might be burning off some coolant, although, for the life of me I couldn't tell you why. I've never swaped out a cam before myself.
