I'm redoing my upper and lower intake. I noticed that the hose runs from the PCV to the upper intake on the side and then it goes to the bottom of the upper. Do I need it hooked up in two spots like that?
Thanks. I might be wrong but I thought the vaccum might be stonger if its hooked up in two spots. As you might know, I'm going to run a second PCV from the drivers side valve cover as you have it in your write up.
Thats two PCVs going into one hose through an oil sperator. Should be bone dry.
