CManT1914
91LX_5L said:ALSO!!! With the ACT sensor do you want it facing so the sensor is open with the inside of the air tube (so the air blows thru it) or do you want it twisted so the edge of the plastic is where the air hits (so it doesnt blow directly on the sensor)?
I always turned mine so the sensor was being hit directly with air, it kinda defeats the purpose of an air sensor if the air isn't directly hitting it I think.
I thought that the ACT was also called the IAT (intake air temperature)? That's what I've always called it.
Also might wanna check your ECT (engine coolant temperature), as this has been known to affect performance. Check the supplied voltage, and do an ohms test.
