Why switch to 5 lug?
  • Thread starter Thread starter deftsound
  • Start date Start date Jun 6, 2010
1 of 2 Next Last
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Jun 6, 2010
  • Jun 6, 2010
Well im wanting to put a new set of wheels on my 87 but am debating whether to switch to 5 lug or not before i do. Besides having more wheel options by switching to 5 lug, why do people do it? Is it really worth the money or should i just go ahead and get a set of 4 lug wheels that i like?
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Jun 6, 2010
  • Jun 6, 2010
I did cobra brakes on my car.
Yes, there is a huge difference in performance, and it looks so much better, especially if the wheel you choose is an open spoke design. Instead of looking through the spokes and seeing suspension parts, you see a massive rotor. To me it's almost part of the wheel and tire package.
deftsound
Apr 6, 2004
945
Texas City TX
Jun 6, 2010
  • Jun 6, 2010
What are the performance differences, assuming im keeping the stock brakes?
lancec2c30
570
Washington
Jun 6, 2010
  • Jun 6, 2010
You don't consider better braking an add to performance?
skunk21
1,203
Taxachusetts
Jun 6, 2010
  • Jun 6, 2010
stock brakes no performance gain. larger brakes= more swep area or rotor surface area, this gives more consistant braking with less fade and more leverage ( the more repeated stops you make.. more so under hard braking the more heat is built up in the rotor/pads and the more pedal effort is the result until they basically hit the floor). figure in a good set of pads with a good friction material for the street and you have vastly improved the braking over stock.
deftsound
Apr 6, 2004
945
Texas City TX
Jun 6, 2010
  • Jun 6, 2010
Of course i do, Im just not ready to spend that kind of money yet. However, I did find a 5 lug conversion kit on ebay for 325$ so i might go ahead and do it. I really don't think the stock brakes are all that bad to be honest. And this is coming from someone who's used to 13" cobra brakes...
I really would like to put a set of bullits on, and I think i could probably trade my old 99 gt wheels along with the ponys for a set plus cash maybe so i think im leaning towards the 325$ 5 lug kit...
lancec2c30
570
Washington
Jun 6, 2010
  • Jun 6, 2010
If it's the $325 kit that uses your stock spindles like I'm thinking it is, you won't be able to run center caps with the bullitts.
skunk21
1,203
Taxachusetts
Jun 6, 2010
  • Jun 6, 2010
you asked about the performance gain. the stock brakes aren't horrible but still sub par. I made them a little better by installing a better blank and pads + tires and watching my driving but they would be dead with repeated hard braking, auto-X or a track day. for normal cruising they are fine.
281pony
2,681
Oly, WA
Jun 6, 2010
  • Jun 6, 2010
with 5 lug you get that warm fuzzy feeling, people dont look at you funny anymore, you have unlimited wheel choices, unlimited brake upgrade choices, the lugs look more proportional on the wheel, ect?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 6, 2010
#10
  • Jun 6, 2010
  • #10
If you ever make silly amounts of power (think: 8-9 second quarter mile), you have less of a chance of shearing the lugs off during a launch, haha.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jun 6, 2010
#11
  • Jun 6, 2010
  • #11
http://www.youtube.com/watch?v=_XihzfXFPr4
this fella managed to break 5
P.S while the camaro was falling apart, that van definitly did a wheelie
xherdlr
159
Hendersonville,Nc
Jun 6, 2010
#12
  • Jun 6, 2010
  • #12
I have $200 in my 5 lug conversion. Went to a junk yard and bought spindles,rotors, and calipers from a 96 v6 mustang(same as gt) and got 2 passenger side axles from a ranger with drums. I think it was passenger side, if not Im sure Ill be corrected. The only thing else that I bought was a Maximum Motorsports stainless steel line that mates the 95 and up calipers to the stock fox body lines.
If the $325 kit is just 5 lug rotors that fit stock spindles? You wouldnt be able to use the dust cap without modifing the wheel. These are from a lincolin/ranger and is a cheap way to upgrade to 5 lug. But, it still leaves you with limited wheel selection. Basically the 94/95 gt 16 inch wheels are all you can run with dust cap.
deftsound
Apr 6, 2004
945
Texas City TX
Jun 6, 2010
#13
  • Jun 6, 2010
  • #13
I assume this is the one you guys are talking about that uses the stock spindles?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140412715476&viewitem=&category=33564
Does the kit from latemodel resto use the stock spindles as well?
If not, which kit does? I'd really rather not go the junk yard to find the parts, around houston it seems like finding a mustang in a junk yard is hard to do.
I plan on running stock 2003 17x8 bullits btw....
281pony
2,681
Oly, WA
Jun 6, 2010
#14
  • Jun 6, 2010
  • #14
if your like most mustang modders, you will end up doing it over if you cheap out the first time.
my 5-lug stuff cost me 750 + a few small things. i waited and scored the m2300 kit upgraded for that.
make sure you can live with your axle choice.. ranger axles = stock width. 94-98 axles = .75 wider per side. i got those axles with my kit, and running a 9" rim with any decent sized tire was a BITCH.
if you pick up one of those ghetto 300 dollar kits, imo, id just leave it 4 lug. cause you can run a 5-lug rim, but the choices are so minimal if you want a center cap. then if you go to run any of the good brake setups, you swap it all over again.
go to the junkyard/ebay/forums, get some sn95 spindles and stock gt brakes, then pick your rear end setup.. drum, disc, then axle length. atleast leave yourself the option to upgrade later without being a nightmare.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 7, 2010
#15
  • Jun 7, 2010
  • #15
are you on drugs, ever take your car to the canyons and actually need to stop?
deftsound
Apr 6, 2004
945
Texas City TX
Jun 7, 2010
#16
  • Jun 7, 2010
  • #16
No, i live in south Texas, there are no canyons.
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Jun 7, 2010
#17
  • Jun 7, 2010
  • #17
the kit your talking about its the cheap way out, youll be back in less than a year redoing it. its using mark 7 spindles, and they stick out further so you wont be able to run bullitt wheels with center caps. you cant run most of the 5 lug wheels with center caps. theres only about 4 or 5 sets of wheels you can run with that kit with center caps. i cant find the site that explains it all but if i do ill post it. with that setup its pretty much a 5 lug fox factory setup. you have bearings in the rotors, and studs on the rotors. with sn95 stuff you get spindles with sealed hubs and studs on that, then a normal rotor.
deftsound
Apr 6, 2004
945
Texas City TX
Jun 7, 2010
#18
  • Jun 7, 2010
  • #18
I'm really starting to think im just going to say ***** it and get the 4 lug saleen wheels i want. Ill never be autocrossing this car, the only track duty it will see is occasionally at the drag strip. This is going to be a cruiser....
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jun 7, 2010
#19
  • Jun 7, 2010
  • #19
you could just get 5 lug axles, ranger drums and SVO discs for the front.
Im running GT brakes in the rear, SVO rotors up front with bigger SVO calipers and the car stops good, and i dont have a ton of money in the setup
xherdlr
159
Hendersonville,Nc
Jun 8, 2010
#20
  • Jun 8, 2010
  • #20
Keep your eyes open. There are stang parts coming up all the time. I have a set of 94/95 spindles Id let go. You will need rotors and calipers. Part of the fun is walking the j/y and looking over all the cars. There are kits out there, but you will pay big money for them! The m2300 is basically brake system from a 94up cobra. If you know what parts to buy, BuyFordRacing has cobra calipers and rotors on sale often. G/L with search.
1 of 2 Next Last
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 9:43 AM
Sparky714
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
