I'd at least look into it. Mine works awesome.You can use the stock VSS sensor on the speedo for the rear wheel speed, and then just add one to the front wheel. Compare the trans output shaft speed to the front wheel speed in the MS3 and bingo, traction control. I'm going to try the method @nicholase mentioned first though and see if I can make that work the way I want.
