wideband o2 question
rockyracoon
874
27
49
margate NJ
I had a wideband setup on my SVO that I used to simulate a narrowband signal to the computer so my question is since my 5.0 has 2 o2 sensors how (if possible) would I hook one up to the 5.0. Equipped mustang. Would I simply need 2 wideband sensors ?
Well the W/B controller that I had had an output that Was realtime o2 ratios but it (the controller) would convert the output signal to an analog signal and you could actually incorporate a bias in order to trick the computer into running the engine more lean or more rich and that's what I would like to do with my. 5.0 .its referred to as narrowband simulate. Obviously WOT would not be affected so for instance if I wanted to run at 15.0/1 I could trick the computer into doing so.
