  • SN95 4.6L Mustang Tech
Wiggle in the driveshaft
  • Thread starter Thread starter COramprat
  • Start date Start date Mar 11, 2007
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 11, 2007
  • Mar 11, 2007
How much play should I have in my driveshaft? I can rotate it about 1/4 inch side to side and there is a little up and down play, very little. I'm thinking I shouldn't have any up/down at all. Bad u-joint? It's acting a little like it did when the u-joint went out last time but I don't remember having so much rotational play in it.
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 11, 2007
  • Mar 11, 2007
are you getting vibrations at certain speeds?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 11, 2007
  • Mar 11, 2007
Just in 5th right now at around 65-75. After I had it off the ground though it was vibrating in each gear. I pulled the DS off and the rear U joint is fine but the front one has a tiny bit of play in it. I'm going to swap it out and see what happens.
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 11, 2007
  • Mar 11, 2007
i'd be willing to bet that's it. but i have been wrong before
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 11, 2007
  • Mar 11, 2007
first thing I would do is drop the shaft and make sure the play is not in the pinion.. you can check that by moving the pinion flange up and down, any play there is bad and you will need pinion bearings and a new crush sleeve
if there is no play there then replace your u-joints.
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 11, 2007
  • Mar 11, 2007
you sir just scared me. i've been getting vibrations too & i dropped my stuff to take the tranny out (for another reason). so i had to run out & double check that just now too, haha
i'm good to go
Mike97gt
it doe snot
10,633
Mar 11, 2007
  • Mar 11, 2007
i'm good to go
it's also possible to get a vibration after you dropped the driveshaft if you did not index the shaft.. it should always be installed the same way it came out.
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 11, 2007
  • Mar 11, 2007
that i can say for sure was done. all the stock oil markings were still there & they all lined up
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 11, 2007
  • Mar 11, 2007
I swapped the fwd u-joint since that was the one I was getting the play in. Put it all back together...no change. The pinion moves rotationally with some slack...like and inch around until the wheels move. No up/down, side to side at all.
I swapped the old DS for an aluminum one a while back. I just plopped it in because I didn't have good info on how to put in the new one. I dropped the shaft again during my clutch swap...maybe I didn't get it back in the way I had it. I think I'll rotate it 180 and see if that helps.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
