Will an old Distributor work??
  • Thread starter Thread starter FordRacing302
  • Start date Start date Oct 22, 2005
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
Oct 22, 2005
  • Oct 22, 2005
My '83 doesnt run, gets gas but no spark...At one time it was a TBI v6, but has been replaced with a 302, and theres a mess of wires under the hood...Right now it has an electronic distributor on it, with a ignition module that I think is fried...So I think I should just remove the distributor and trade it in for a regular vacuum advanced distributor, but I dont really know much about wiring so Ive come here to ask you guys what all I need to do...Where do I wire the coil to??....Is there anything I need to replace??...Im just thinkin that im gonna put in the new dizzy, hard wire it and hope it will fire, do you think that will work???
Im planning on doing this today so I need the info ASAP, Thanks in advanced
hllon4whls
BANNED
2,567
Covington
Oct 22, 2005
  • Oct 22, 2005
For ultimate in simplicity, a HEI dist for a ford has minimum wiring. You need to know if you have a roller motor or not to get the right dist gear. Summit has a drop in kit for a ford for 225 with the roller steel gear in place.
As long as you are carbed, you can go with whatever you want. I find adding a duraspark ignition is fairly easy, but I am good with wiring.
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
Oct 22, 2005
  • Oct 22, 2005
Im on a very tight budget, and actually the car is for sale right now for $500, but I had a friend offer me $700 if it was running, so I thought if I could hard wire a regular distributor then it would fire....So your telling me that it will work?? I dont need to replace anything else?
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
Oct 22, 2005
  • Oct 22, 2005
Bump....
Sorry about bumping so early but im really kinda in a rush
rd
3,316
63
109
Ocean Springs MS
Oct 22, 2005
  • Oct 22, 2005
A properly wired Duraspark is what you want. This needs a 12 volt wire from the ignition to the coil for start, and then ignition run power through a ballast resistor for the run position. Nearly any Duraspark 2 box and coil will work. Not sure how to wire a tfi to run carbed. Your 83 may have the correct wires already to the coil. If so, then all you need is power, 12 v, in both start and run to the Duraspark module.
If you have to buy one, get a Duraspark ignition module for a 77 to 79 Ford F150 with any v8, 302, 351, 400, etc. The cheaper the better.
Not sure if this helps, but I am not sure TFI works well without the computer.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
